Hi Beam indicator on dash
Old 11-05-2000, 07:24 PM
soupy264's Avatar
soupy264
soupy264 is offline
[font size="1" color="#FF0000"]LAST EDITED ON 05-Nov-00 AT 08:26 PM (EST)[/font][p]I had a problem with a ground and blew both headlight bulbs. after replacing the bulbs the lights work fine but the hi-beam indicator on the dash stays on all the time. I suspect that a relay got welded buy the ground problem. Does anyone know if there is a relay tha turns the indicator on,and if so where it's located? thanks PHIL It's on a 90 F350
Old 11-06-2000, 09:27 AM
bgodkin's Avatar
bgodkin
bgodkin is offline
Did you try changing the bulb in the indictor yet. It fixed mine. Hope this helps.
Brad Godkin
1986 F350 CC/SRW
6.9liter/C6
Old 11-06-2000, 06:20 PM
soupy264's Avatar
soupy264
soupy264 is offline
THANKS,I'll try that .
Old 11-07-2000, 03:39 PM
deleontow's Avatar
deleontow
deleontow is offline
[font size="1" color="#FF0000"]LAST EDITED ON 07-Nov-00 AT 04:40 PM (EST)[/font][p]Does your high and low beam switch work ok, you may have a problem with the high beam switch on the floor. Also you may have a bad ground on the headlights, this will cause a feed back and make the light stay on all the time, try this, find the ground wire that goes to the head lights and using about a 12 guage wire, ground the circuit directly to the battery ground, if this makes the light go out, you need to find the ground conection and secure it.
Oh and one more item, there is no relay for the high beam.
Dave
http://a2ztowing.homestead.com/a2ztowing.html
Old 11-08-2000, 05:48 PM
skhawks's Avatar
skhawks
skhawks is offline
saxmancon
05-02-2022 04:48 AM
PutnamJct
1983 - 2012 Ranger & B-Series
08-04-2017 07:27 PM
oft
10-17-2014 08:46 PM
bicyclemonkey
21
11-16-2010 03:53 PM
Quick Reply: Hi Beam indicator on dash
