Bed Slightly Unlevel - Ford Truck Enthusiasts Forums
Old 06-06-2004, 07:11 AM
ringking's Avatar
ringking ringking is offline
ringking is starting off with a positive reputation.
Question Bed Slightly Unlevel
This may sound stupid but I have noticed, especially in some of the older ford trucks, that the bed is slightly unlevel or tipping to one side. I have a supercab FX4 2004 F-150 and I have this same problem, again it is not really that big of a deal. I'm just curious if anybody else has had this same issue. It is enough that if you look carefully you will notice and yes I'm on level ground. I went to the dealership and looked at all of the trucks there and they seemed to be ok. Would this have to do with how the truck is put together on the assembly line?
Thanks for any help.
Old 06-06-2004, 08:39 AM
PhrEEkSh0w's Avatar
PhrEEkSh0w PhrEEkSh0w is offline
PhrEEkSh0w is starting off with a positive reputation.
The bed on my truck is perfectly level. I've seen what you are talking about on older trucks. I'm guessing, but I always thought the bushings were worn down.
Not sure what would cause it on a newer truck. If it's really bad maybe have the dealer look at it.
Old 06-06-2004, 08:54 AM
ringking's Avatar
Thumbs up
That's kind of what I'd assumed. You just sometimes need that second opinion. Well, thanks for your time.
Old 06-06-2004, 12:54 PM
jra jra is offline
jra is starting off with a positive reputation.
Have you actually taken a tape measure and measured the bed in relation to the cab of the truck? If so, how far off is it?
Old 06-06-2004, 01:07 PM
Cincy F150 Cincy F150 is offline
Cincy F150 is starting off with a positive reputation.
Do the body lines on the side of the bed match with the cab? If you want to square it up, you can get some alignment shims from a tire shop and slip them in between the frame and the bed mount. They have different thickness tabs so this is an easy fix.
Old 06-06-2004, 01:36 PM
zer0cool zer0cool is offline
zer0cool is starting off with a positive reputation.
I had a 2000 Explorer, that the day I drove it home from the dealer, I noticed it sat low on one side. i took it back to the dealer and they told me it was fine. I had them walk the lot with me to show me another one that sat that way and they couldn't. They wheeled it back to the service department and made some adjustment to the suspension, which took about 10 minutes. They could have saved themselves an hour of arguing about nothing being wrong if they'd have just spent the ten minutes fixing it first.
Old 06-06-2004, 03:38 PM
ringking's Avatar
It really doesn't bother me a whole lot, I just wanted to see if I was alone with this issue. If it continues to get worse or really starts bugging me I will take your advice and shim one side. Although it is worth a shot to go to ford and have them fix it since it is after all a Brand New Truck. I will try ford first. Then go from there, thanks for the replies.
I have not measured it but I will do that also and get back to you.
Old 06-06-2004, 04:02 PM
Neil's Avatar
Neil Neil is online now
Neil is starting off with a positive reputation.
Post
ringking: Over the years, I've had 2 new Ford trucks delivered with crooked beds. I don't recall how they fixed the first one, but the most recent one was my 2001 Super Crew. A few days after I picked it up, I had to return it to the dealer for some wiring problems. While it was sitting in their shop, I happened to walk past the open bay door and noticed that the right rear corner was lower than the left rear corner. You could sight across the tailgate to the front of the box and see an obvious difference. I asked the service writer to take a look and he could see it as well. As soon as the tech was finished with the wiring problem they took it over to another bay. The tech asked me how much I thought it was off of level. He crawled underneath with his air wrench, loosened the right rear bolt that secured the bed to the frame. He stuck a pinch bar between the cross-member of the bed and truck frame, lifted the bed and slipped a 1/4 inch spacer around the bolt, removed his pinch bar, tightened the bolt and PRESTO, the bed was level. He had a selection of spacers available. I'm not sure if they were a Ford part or something that had been custom made.
Old 06-07-2004, 07:03 PM
ringking's Avatar
That makes me feel better. I think that when I take it to the dealership for other work I will mention what you said they did to your truck. I would love for it to be level like it should have been in the first place. Thanks for all your help. This forum is great!
OMG this 16 going to drive me crazy radium 6.7L Power Stroke Diesel 60 06-15-2016 08:33 PM
1986 Bed not leveled. 1967 Tempest 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 01-31-2014 02:01 PM
Fifth wheel guys with a lift. Fordsonly General Diesel Discussion 8 01-30-2008 01:27 AM
Leaf Spring Shims? PowerstrokeJunkie 1999 - 2003 7.3L Power Stroke Diesel 9 02-09-2006 11:49 PM
Is your Ranger sitting uneven/unlevel?? csallen Ranger & B-Series 8 08-21-2004 10:10 PM
Tags
200407, 2007, 2010, alignment, bed, crooked, f150, f350, ford, fx4, ranger, truck, trucks, unlevel, unleveled
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
