Draglink question
Draglink question
The manly front end of the '54 is sitting in the driveway, separated from the mother ship, as it were. In earlier times I had purchased front springs, tie rod and ends, kingpin set and recently a pitman arm from FTE brother Roger. Have the draglink end kits to go in the link and a question.
Do the little cups in the ends bear all of the weight of the ball or does the ball find itself on the inner walls of the draglink ends? I ask because the inside of my dl is chewed up where the ball has run rampant. I'm not sure if my question is posed properly... but the upshot of the whole thing is.... Do I need a new draglink? If so... who has one?
I'm talking the one that comes with the deep discount.
Redoing the mastercylinder and wheel cylinders and brake hoses etc. has put a big gap in the truck budget. Or... is it ok to use this one? thanks. himmelberg
The cups should bear all of the load, the ball should not touch the inside of the draglink tube. If the new cups seem loose in the old draglink tube, then you're going to have to replace it. If the cups fit reasonably well, I would reuse the draglink. I had a similiar problem with my draglink. '52 F1 ...Terry
Peter
48 - 56 use the same drag ling - That Lil Ol Place in Kansas has them for 120
Several places have the shackle bolts and bushing. My Front pins wer worn half way through.
Also check the ball studs on both ends of the drag link, the are designed to be round, not oval shaped like mine are.
Hi
I have one that I bought new for my first 56 (that was about 10 yrs ago). Used it for less then 100 miles (switched the frt susp to a Must 11) I will sell it for $60.00 plus shipping from Mi (I have the arm that attaches to the draglink and steering gear it goes with the draglink if you want it)
Chuck
Chuck
