Propane injection for diesel pick-up's - Ford Truck Enthusiasts Forums
Old 01-03-2001, 01:13 PM
jda jda is offline
jda is starting off with a positive reputation.
I have been hearing a lot about the propane injection systems for our diesel engines in pick-up trucks. The only thing I have heard so far is the wonderful and good, and not from the makers of the systems either. This is from the individuals that are putting the systems on their trucks.
So what is the bad side of putting one of these systems on a diesel? Does it make the engine run hotter? Make it blow head gaskets more often? Burn up the valves sooner? Burn a hole in the piston? I am interested in the long, long term affects on the diesel engine. How long have these systems been around, long enough for anyone to know the long term affects?? From all I have heard, the propane gives almost as much more power as a turbo, but costs a lot less. I know you would have to keep refilling the propane, and keep paying for it, but my understanding is you have a switch where you can turn off the propane if you don't want/need it.
Mine is a 1987 F-250 4X4 6.9 liter four speed manual with positive traction.
Anyone out there ever used one of these propane systems, if so, for how long/how many miles, what are your experiences?
Old 01-03-2001, 07:36 PM
hendrixj hendrixj is offline
hendrixj is starting off with a positive reputation.
NEED HELP.. MILD TURBO PROPANE 5.4 TRITON FUEL SIPPER BUILD DAKIND1 1999 to 2016 Super Duty 8 01-06-2013 01:20 PM
Propane injection hairyboxnoogle Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 03-13-2010 02:24 PM
Is Propane or water/MEOH Injection worthwhile? thedaddycat Bio-diesel, Propane & Alternative Diesel Engine Fuels 7 04-05-2008 01:42 PM
Propane System on a 4.9L F-250 abelmoreno 1987 - 1996 F150 & Larger F-Series Trucks 0 01-24-2005 10:31 AM
Propane long term effect on PSD Strjock81 Bio-diesel, Propane & Alternative Diesel Engine Fuels 3 01-03-2004 08:25 PM
Tags
1987, 67, 6l, boost, diesel, engines, feedback, ford, forums, injection, negative, pick, pickups, propane, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
