Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Engine Coolant Light Stays On
Old 12-16-2004, 11:24 AM
dcohen01's Avatar
dcohen01
dcohen01 is offline
thanks-any ideas about the rubbing/screeching sound coming from the steering column?
Old 12-19-2004, 07:06 PM
bailey2309's Avatar
bailey2309
bailey2309 is offline
I just had my 2003 escape in a couple months ago for the coolant light staying on. At first it was on intermittently, then it just stayed on. I took it in and they fixed it, said there has been a problem with air getting in the line and they have to flush the air out and refill correctly. My escape was no longer under warrenty, but because this was a problem I was told they have seen often, I was not charged. Could be your problem- Hope it helps.
Old 08-31-2006, 05:22 PM
schweizer's Avatar
schweizer
schweizer is offline
Where do I find the plug for the sensor? I've been ignoring mine for almost 100,000 miles
Old 08-31-2006, 05:47 PM
ove1's Avatar
ove1
ove1 is offline
The connector is on the bottom of the tank. Remove one bolt holding the tank on and you should be able to get to it.
nmlewis
08-10-2017 05:04 AM
wendal
06-10-2017 11:35 PM
MDSLIGHT
1999 to 2016 Super Duty
01-31-2016 06:57 PM
sadyedog1
07-11-2011 05:29 AM
bronco_94
1978 - 1996 Big Bronco
06-23-2004 05:14 PM
Quick Reply: Engine Coolant Light Stays On
