radiator removal - Ford Truck Enthusiasts Forums
radiator removal
Old 06-02-2004, 11:46 AM
yellow73bb yellow73bb is offline
yellow73bb is starting off with a positive reputation.
radiator removal
Earlier this year, I took my F350 in to the dealer because there was a lot of oil on the intercooler. It turns out that the intercooler had a leak in it and oil taken in from the valve cover breather was getting released onto the intercooler and radiator. At the time, the intercooler was about 1/4 to 1/2 covered with dirty oil. They replaced the intercooler under warranty. On Saturday, I was putting in a transmission cooler, and noticed that when they replaced the intercooler, they didn't clean the radiator, so about 1/4 of the surface area of the radiator is plugged with dirt/oil. I called the dealer, and they said that cleaning the radiator isn't part of replacing an intercooler.
So, I'm a little miffed at the dealer. I didn't buy the truck from them, so I probably don't have much leverage to get them to clean it.
Does any one know how difficult it is to remove the radiator? I guess I will need to pull it myself and clean it.
Intercooler Removal Traildust 1999 - 2003 7.3L Power Stroke Diesel 9 11-15-2016 09:23 AM
Intercooler install King7765 1994.5 - 1997 7.3L Power Stroke Diesel 55 06-08-2016 06:45 PM
Intercooler in your IDI? Ford F834 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 04-07-2012 07:32 AM
6.0 Intercooler Install Writeup jtharvey 1999 - 2003 7.3L Power Stroke Diesel 20 03-14-2008 09:39 AM
Oil leak in intercooler yellow73bb 1999 - 2003 7.3L Power Stroke Diesel 6 01-25-2004 12:19 PM
Tags
2003, 2006, 60, 60l, 73, diesel, explorer, f250, f350, f450, ford, powerstroke, radiator, removal, removing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
