97 Ford f-250 Diesel problems - Ford Truck Enthusiasts Forums
Old 02-20-2001, 11:20 PM
snownuts snownuts is offline
snownuts is starting off with a positive reputation.
I have a friend with this truck that just seems to have a mind of its own. SOmedays it runs good others it doesn't have enough power to get out of its own way. The ford dealership and the local transmission shop haven't found anything wrong with the transmission or engine. The truck is off warranty and would like to find a simple fix rather than putting a new computer; if that is indeed the problem. Lately he has been blowing fuses also. Has anyone out there had any troubles similar to this?? What could it be and how can you fix it?? THe computer says there is nothing wrong.
craig
Old 02-21-2001, 12:10 AM
jbhf250 jbhf250 is offline
jbhf250 is starting off with a positive reputation.
I welcome you as a new member
It may help you to repost your question in the proper area to get the answer you need ....Some members only `post` responces in the area they are acustomed to reading..
>>Topics do not have to be about automotive products. Anything goes so long as its clean. DO NOT USE THIS FORUM FOR QUESTIONS ABOUT YOUR TRUCK, USE THE APPROPRIATE SECTION<<
__JOHN__տ
FTE Club #7
Member-
http://www.cruisin-north.com/
Santa Rosa, Calif.
72 F-250
ICQ#6030753
http://www.ford-trucks.net/users/jbhf250/
http://ford-trucks.com/pictorial/big/1972_f250_2.html
Old 02-25-2001, 11:01 AM
whd507 whd507 is offline
whd507 is starting off with a positive reputation.
you might have the alternator checked to see if it is producing voltage spikes, also pulling fuse #9 will reset the computer, and I recommend doing this every now and then, to allow the computer to "re-boot" and adjust to current engine condition.
Old 02-26-2001, 05:22 PM
deleontow deleontow is offline
deleontow is starting off with a positive reputation.
Old 07-03-2013, 11:10 PM
pilgrimbizket's Avatar
pilgrimbizket pilgrimbizket is offline
pilgrimbizket is gaining momentum as a positive member of FTE.
Quote:
How true is this?
Old 07-04-2013, 01:16 AM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Not true. The PCM in these trucks don't learn you driving habits like the newer ones
Old 07-04-2013, 07:09 AM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Wow, this is 12 years old. I was confused when I read warranty in the first post..
2007 Edge Computer & Transmission failure phoskins Crossovers 9 04-01-2016 12:59 PM
I am in need of some fellowly advice on my 2000 7.3 f250 SD 2wd I am Murphy law 1999 to 2016 Super Duty 4 03-21-2016 07:31 PM
Computer/trans/TC issue lawdawg79 1999 to 2016 Super Duty 25 08-12-2015 07:25 PM
Chasing Codes... three left scooterspal Ranger & B-Series 49 08-06-2015 02:47 PM
What is causing my rough idle? F250 with 351W bebyb 1987 - 1996 F150 & Larger F-Series Trucks 8 04-07-2014 08:18 PM
Tags
250, 73, 97, commonproblemswith97f250diesel, diesel, f250, ford, httpford, problems, recalls, troubleshooting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
