97 F-150 A/C Relay
97 F-150 A/C Relay
I have a 97 F-150 that the A/C went from blowing cold to hot instantly. I have done the following;
1. Checked fuse. Was good.
2. Checked Low Pressure connection.
On this, I jumpered the connector and could not get the clutch to engage. I also checked to make sure I had 12v from that point, which I did.
3. Checked the power to the clutch assembly. Got nothing. I also put 12v directly to the clutch and it poped in just fine.
Based on all of this I think I have a bad relay between the low pressure sensor and the clutch assembly. The only problem is I cant find it. If anyone knows where this relay is located I sure would appreciate the help.
Hi Gator and welcome to the forum
Your truck doesn't use a relay for the a/c clutch.
You have a low pressure cycling switch which I assume is the one you jumped. It is on the accumulator.
There is also a high pressure cutout switch on the high pressure line. It looks pretty much like the low pressure cycling switch. I would try jumping that and see what happens.
Thanks for the welcome Racer.
If there is not a relay on the 97 I guess thats why I couldn't find the darn thing. I did jump the low pressure switch and got nothing. (BTW-I am extremly happy that the clutch and compressor seem to be fine) What it comes down to is that I am getting no power to the clutch assembly at all. Do you think replacing the low pressure switch may do the trick?
Bad AC Compressor???
OK, I have been reading for about 4 hours as to why the AC Clutch was not kicking in, did the usual checks described above, and findlay added a little R134a to the low pressure side and just as I added a very little amount, with the AC dash and key on, I heard the clutch click...
So... I cut the can off and disconnected the hose, and cranked the engine...
Well the clutch was smoking when engaged, and not turning... I cut the engine...
Does that mean my compressor is bad and locked up?
Bought the truck a year ago, it had been sitting since 2008... and the wire to the compressor was unhooked... No telling how long since it had a working AC...
Any input would be helpful...
I know this is an old post but I was wondering what wires do you mean that connect from the functioning switch what color are they
V8SHO
09-27-2017 10:14 AM
MichaelA2014
07-25-2017 04:43 PM
MichaelA2014
07-21-2017 07:34 PM
