2.9L Hardly running after warmup
Hi, I am new to the forums. Have been on the site many times, but finally needed some technical info.
I am currently working on a Ford 2.9L bronco II. The engine runs great when it is cold. But after warmup the idle drops down to about 500 rpm. When I try and push the throttle the engine dies. When I shut the engine off and let it cool for about 5 minutes it runs fine until it warms up again. I am thinking this may be something in the distributor (Ignition module) or the such. Help would be much apprieciated. Thanks
I'm 87 XLT: start with trouble codes from the computer (see www.dalidesign.com/hbook/eectest.html for instructions). Remember that codes point to circuits rather than to individual components. If/when you post the codes here for further help, it helps to not only give the actual code numbers, but also to note which type of code each is (KOEO hard fault, continuous memory code, or KOER).
same problem? runs good cold/wide open...
HI. New to the forums as well.
We have a 87 2.9 that seems to have similar symtoms...
It runs just fine, as long as it's cold. Seems, as soon as the thermostat
pops open, it runs like crap. One thing I saw someone post caught my
attention - when the throttle is wide open, it also seems to be o.k.
We've already replaced the ignition module, rotor, coolant temp. sensor,
and fuel filter. The check engine light doesn't come on, which is one thing
that is boggling us.
The odd thing, is that it was running just fine, then one afternoon, it just
started doing this...
Going to try a new 02 sensor this week, following the advice of an earlier
post from 87 XLT. I'll post up my results as soon as we get it done.
You should also try and check your fuel pressure when it's cold and then again when warm to see if there is a difference.
When MY 87 was pinging/stalling off the line I hooked up the code scanner, 2 minutes later it flashed a code 53 "throttle position sensor voltage is to high" A couple more minutes to test the TPS with an ohm meter & sure enough it was shot. Took a couple minutes to replace it & problem solved. When the cruise control quit working I pulled the codes & got a code 29 "vehicle speed sensor- signal voltage is too low". Replaced the VSS & that problem was solved. So take the 2 minutes to pull the codes & post them here.
duh!/thanks
Shows you how much I know about this damn truck, heh. Only had it a few
weeks so far...Thanks for the heads up on the phantom light, 87xlt, hehe.
I guess I will change my plan of attack, to grabbing a CP-9015 today,
and hopefully pulling some codes to make this all a lot simpler.
Thanks for the welcome guys, and the quick response advice!
cheers!
cheers!
steve1999
11-06-2001 11:00 PM
