1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Rear Taillight Replacement with Amber lens?
Old 05-31-2004, 11:40 AM
krelvinaz's Avatar
krelvinaz
krelvinaz is offline
Question Rear Taillight Replacement with Amber lens?
Does anyone make a replacement taillight assembly for a 250 that has a separate amber turn signal light. Not sure it is even possible since I would guess on a regular configuration, the turn signals and brake lights are the same.
Just curious.
Old 05-31-2004, 03:08 PM
V10man's Avatar
V10man
V10man is offline
Yes they do. In Austrailia! search over at www.ford-trucks.com Someone over there did. You have to redo the wires to seperate the brake/turn signals.
Old 05-31-2004, 04:47 PM
Bordaine's Avatar
Bordaine
Bordaine is offline
Take A look at Ford ausie site
http://www.ford.com.au/showroom/ligh...Super_Duty.asp
They look cool w/ amber turn signals. You can not have amber shining rearward as A clearence light, turn signal only. You will have to wire it that way.
Old 06-01-2004, 03:01 PM
krelvinaz's Avatar
krelvinaz
Interesting...
Will have to check into the possible wiring changes. I suspect that it would need a different switching box though.
I really like amber turn signals in the back better than using the red for both brake and turns.
Old 06-01-2004, 04:53 PM
cgl's Avatar
cgl
cgl is offline
Anyone else notice how the Aussie Ford's don't have the 6.0. They still have the 7.3..
Old 06-01-2004, 06:02 PM
wiingnut's Avatar
wiingnut
wiingnut is offline
I noticed that also about the 7.3 too. Did you also notice that the only models they offer to the Aussie's are the XL and XLT. Also the front ends for both models look like the low end XL's here in the states and they have very limited options available .
donmi
02-18-2015 10:32 PM
sere0501
01-03-2015 12:06 AM
mustangpt
13
11-26-2014 02:39 PM
mwvdub
03-11-2009 04:10 PM
1991_BigBoy
1978 - 1996 Big Bronco
05-12-2003 09:52 PM
Quick Reply: Rear Taillight Replacement with Amber lens?
