05-31-2004, 11:26 AM
302 to 302 H.O instalation questions for warranty
Ok me and my father have installed a 302 h.o long block from a company like jaspers down in the states,it runs great by the way.My questions are about there warranty card needed for warranty,now this is the second one weve put in the first we put in in jan and there mains were machined wrong so after 3000kms on the way about 300kms from here it lost all pressure,well the card i had before was just askin 3 questions about the oil pressure,easy enough to fill out.Now weve already got this one installed i just want to know what to put in for some of the questions about gas analaysis at idle and at 2100rpm such as HC_ CO_ O2 _ CO2_.I also want to know what the total advance should be i know intial timing is 10btc. Know my last and final question what would you put for priming oil pressure? we turned the pump over with a drill would it still be in the 40 psi area such as my cold start psi? Well thanks for any replys to these questions.
