Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-30-2004, 01:04 PM
DPS3749 is starting off with a positive reputation.
Changing Fuel Filter
I drove a tractor-trailer for 30 years, but am ignorant of diesel maintenance.
I recently bought a '87 F250 6.9 diesel pick-up. I'm a first time diesel owner, and want to know the procedure for replacing the fuel filter. I noticed a valve on the side of filter housing. Is that used to purge any air out of system after replacing the filter? I'm also assuming I should fill the new fuel filter with fuel before installing. I also read somewhere on one of these posts that the engine should be warmed up a bit before changing the filter which aids in easier starting.
Thanks, in advance.
  #2 (permalink)
Old 05-30-2004, 01:55 PM
Spectramac's Avatar
Spectramac is gaining momentum as a positive member of FTE. Spectramac is gaining momentum as a positive member of FTE.
Sounds like you have a good handle on things, go for it!
__________________
Malcolm
97 Explorer 5.0 AWD
87 F250 6.9 CTS turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
