Drilling Main Jets?
Drilling Main Jets?
Im having a difficult time finding Motorcraft main jets, in the "old days" we used to drill out jets. I have one spare pair of jets, they are #54s just like what was in this unit (in a 302 with a rebuilt , new to me, carb) I drilled the #54s out with #52 bit, it seems to be somewhat better. First of all, can anyone tell me what # jets should be in a 302, 2bbl, ???I was told has mild cam (not sure if its true).
Second, anyone have a conversion chart, or just a good handle on what drill size = what jet size? if a #54 jet is the same as a #54 bit, (and it is) then when I drilled it with a #52 drill bit which is bigger, did I make it a #52? or a #56? ....is a #52 jet smaller than a #54? I am thinking about drilling one more size to a #50 bit, is this crazy too big? or is it reasonable that it may need this much fuel, it still seems starved, float level is good, vacuum is good, and drilling to a #52 did help a but... HELP!!
The bigger the number on the jet the more fuel you get. As far as the drill bits iam not sure, lol stupid me. When does it seemed starved. All the time or during accellration or what? I would think that no bigger than a #60 would be pletty of fuel for a 302. Are you running headers and good mufflers to let the engine breath better then maybe you could stand a bit more fuel. Dont know probally just have to keep expermenting. I have bought jets for holly 600cfm carbs and put them in Ford 2-barrells before, so you might check the local parts store for them.
Every book I have seen on carbs, recommends NOT drilling jets because the jets are sized by FLOW not diameter of hole. The jet number is larger as the hole increases, but they are not directly correlated. I agree with LMM on buying some Holley jets, start with about 56 or so and experiment from there.
What is difference between Holly and Motorcraft jet size/number
What is the difference between Holly and Motorcraft jet size/number?
I understand that they use different systems. Is there a conversion chart, or even a formula? Somewhere someone said that one was based on drill bit size (true?) and the other was based on flow/cross section.
Little cornfused...
Kevin
Little cornfused...
Kevin
I ran a wide band F/A gauge ended up between two sizes of jets, one number too lean, other too rich what I used was small tapered clock bushing reamers. Ream, take notes and test drive.
Drilling out a jet can result in less flow as the length of the restriction is increased due to the taper at each end of the jet.
By shortening the restriction length alone flow increases. You can have the same restriction size for more than one jet number.
I recall on Holley jets the flow increase was 3% for every jet number increase.
btw, these guys have motorcraft jets. i've ordered some from them in the past to play with various sizes...
http://www.carburetion.com/ford2v.htm
When you re-jet a holley, do you replace both the primary and secondary or just the primary. Do you need new gaskets for the metering plate and float bowl each time you go in or can the old gaskets be reused? My carb is a 1 yr old 4150.
F-250 WARHORSE
03-21-2017 10:44 PM
73F100*8Mile
04-09-2006 11:18 AM
