Tach Install - 300 I6 - Ford Truck Enthusiasts Forums
Old 05-29-2004, 10:12 PM
Nightrain Nightrain is offline
Nightrain is starting off with a positive reputation.
I bought this tach and I'm waiting on it to arrive right now.Before it gets here,I want to be sure that I know how to install it so I can get it in immediately .
It's going to come with four wires,one power source,one ground,one illumination,and one for the tach signal.I have a question about the illumination and the tach signal.
Illumination -
I want the tach to light up as soon as my headlights are on.It doesn't have to come on with the markers...Just the headlights.Which color-coded wire coming out of the headlight switch will I need to splice into for the signal to illuminate my tach?
Tach Signal -
I'm installing this on the F-150 in my signature.Where will I need to put the tach signal wire,(i.e. the distributor,the ignition module,etc.).
Thanks for any insight.
Nightrain
Old 05-29-2004, 10:22 PM
bigreave's Avatar
bigreave bigreave is offline
bigreave is starting off with a positive reputation.
when i did my i spliced into the main headlight switch for light . For your tach source i ran off the negative side of the coil green wire i think been a whil but mine is a 85
Old 05-29-2004, 11:29 PM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.
Yup, green(negative) wire coming off the coil is the signal source.
For your lighting, look for a blue wire with red tracer under the dash(there's one going to the light just above the wiper switch) that'll hook you into the dash lighting, dimmer and all.
Old 05-30-2004, 12:35 PM
Quote:
Okay,so I run the green wire on the tach to the negative side of the coil?Call me crazy...But which is the neg side of the coil?What color wire will be connected to it?
So for my lighting source,I'll be looking for a blue wire with a red stripe?That will illuminate the tach when the markers,headlights,hi-beams,etc. are turned on?
Thanks fellas .
Nightrain
Old 05-30-2004, 08:11 PM
srercrcr srercrcr is offline
srercrcr is starting off with a positive reputation.
My oem coil says TACH on that terminal. Check it out.
Old 05-30-2004, 08:40 PM
I'll look into that.Thanks srercrcr .
Nightrain
Old 06-01-2004, 01:19 AM
MontanaFord MontanaFord is offline
MontanaFord is starting off with a positive reputation.
what exactly does OEM stand for? i see this term used regularly, but am not sure what it stands for...any explanation would be appreciated...
MontanaFord
Old 06-01-2004, 01:41 AM
howler howler is offline
howler is starting off with a positive reputation.
Original Equipment Manufacturer
Old 06-04-2004, 12:34 PM
Okay...My tach came in today.I think that I've found the wires for the tach signal,(Green wire on coil),and the illumination,(Blue/Red wire under dash).
But,I have a question about my power and ground wires,(Red and Black).I'm thinking of just running them to the pos and neg side of the battery.Is this a good idea?Or,do I need to find a power wire that only gets juice when the key is turned on?If so,which wire in the fuse box will only have power when the key is turned on?
Thanks for any insight .
Nightrain
Old 06-04-2004, 04:01 PM
I got my 'ol tach in .
It was a simple install.I ran the red wire to the positive side of my battery,the ground to a little ground bolt in the cab,under the radio and A/C-Heater controls,the green wire to the green wire on the coil,and the white wire to the Blue/Red wire.Everything works great,although I haven't been able to check the light in the tach yet.I'll have to wait until it gets dark so I can see it .
Thanks alot for the help,as always .
Nightrain
Old 06-04-2004, 07:58 PM
bremen242's Avatar
bremen242 bremen242 is offline
bremen242 is gaining momentum as a positive member of FTE.bremen242 is gaining momentum as a positive member of FTE.
you don't want it to be connected to your battery at the time. It will deaden it. I hooked mine to the radio supply. it is on when you turn the key on.
Old 06-05-2004, 01:39 AM
Yeah...I forgot about that.I'll fix it tomorrow.What color is the wire that runs the radio so I'll be able to find it?
Thanks for the advice.
Nightrain
Old 06-05-2004, 08:47 AM
bremen242's Avatar
that I am not sure of. I just slide mine in with the radio fuse. ghetto, but works.
Factory Tach - Six vs Eight Cylinders? quakerj 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 06-27-2013 01:27 PM
Tach Install ALedbetter1 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 06-26-2013 06:14 PM
Instrument Cluster Illumination Bulb Replacement Nightrain 1997 - 2003 F150 7 12-12-2006 09:06 AM
1997 f250 HD/460 tachometer Zebich Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 02-20-2005 11:20 PM
SunPro Tachometer Installation; Tach Signal Wire and Instrument Cluster Lighting Wire Nightrain 1987 - 1996 F150 & Larger F-Series Trucks 7 12-24-2004 11:01 AM
Tags
1992, 300, 50l, 82, bronco, f150, f250, i6, install, installing, signal, source, tach, tachometer, truck, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
