1989 Ford Radio Wiring Diagram - Ford Truck Enthusiasts Forums
Old 05-27-2004, 11:13 PM
Cruiseomatic's Avatar
Cruiseomatic Cruiseomatic is offline
Cruiseomatic is gaining momentum as a positive member of FTE.Cruiseomatic is gaining momentum as a positive member of FTE.
Arrow 1989 Ford Radio Wiring Diagram
I've got the stock radio and want to hook it up but dont have the wiring harness for it. Is there a way to hook this thing up w/o it? Just tell me whare the power wire goes and a speaker is all I need.
Thanks.
Old 05-27-2004, 11:34 PM
acerockola77's Avatar
acerockola77 acerockola77 is offline
acerockola77 is starting off with a positive reputation.
Old 05-28-2004, 05:54 PM
It requiers the wiring harness,I dont have those.
Old 05-28-2004, 08:54 PM
prcrboy's Avatar
prcrboy prcrboy is offline
prcrboy is starting off with a positive reputation.
You can purchase them seperately. Or check in a salvage yard. I tried once, and only once I might add, to solder the connections. FORGET IT!!
Check with local shops, or even ebay. http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3095166516
Old 05-28-2004, 09:50 PM
I cant just put the wires to the radio without the harness? cuz that what im trying to do. I dont know why but I am.
Old 05-31-2004, 07:06 PM
drewcoolness99's Avatar
drewcoolness99 drewcoolness99 is offline
drewcoolness99 is starting off with a positive reputation.
you still can, if you are determined not to use on just cut off the other harness ad you know what all the wires do from the diagram.
Old 06-01-2004, 12:13 AM
I would if i could,new radio is in truck and I cant get it out.
swap basic AM/FM radio with CD/fm radio? or add aux port work.truck Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 09-14-2015 09:48 AM
original radio, gnd wire location 70-360fe 1967 - 1972 F-100 & Larger F-Series Trucks 2 09-03-2013 10:46 PM
Radio Dimmer wire chi6488 6.4L Power Stroke Diesel 0 01-31-2012 02:39 PM
Ignition wire for accesories Jbrown8988 1999 - 2003 7.3L Power Stroke Diesel 10 12-30-2010 10:58 PM
replace stock audiophile radio MMZ2584 2004 - 2008 F150 2 08-16-2005 03:56 PM
Tags
1989, 89, diagram, digrahm, directions, f150, f250, ford, radio, stereo, sterio, truck, wire, wires, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
