750 cfm too much?
750 cfm too much?
Well, I ordered an edelbrock power package from jegs with a cam and lifters, manifold and carb along with headers. Much to my surprise, I opened the box and it was a 750 cfm carb. I was expecting a 600 or something smaller. Is the 750 too big? My engine is a completely stock 1975 360 . Should I trade in for a 600 or 650, or mess with this HUGE carb?
I will be the dissenting vote. I don't think there is anything wrong with a 750cfm carb on any engine over 350ci as long as you are not at a high altitude location. A properly tuned 750 will meter the same amount of fuel to the engine that a 600 would at any given RPM, but not be as likely to run out of carb under full throttle conditions. I am not saying that a 600 wont feed a 360 adequately, just that I don't see the advantage of switching to a smaller carb when he already has the 750 in his hands.
-Scouder
-Scouder
Originally Posted by Putt
The carburetor airflow ie 600,650,750, etc. has NOTHING to do with whether the carb is running rich!! The jets and metering rods affect the fuel mixture no matter what size the carb is. The cfm rating is the maximum airflow capability of the carb.
-Scouder
eidle
-Scouder
-Scouder
For a stock 360. The Barry Grant site reccomends a 525cfm Road Demon (I assumed the cam duration to be less than 210 degress).
Even if you step up to a 210-220 degree cam and 460 Cubic inches, they still reccomend a 625cfm Road Demon.
There must be some price to pay for having too much carb. I'm thinking you lose some bottom end grunt. How much, I don't know.
this, just for the sake of discussion. There is no doubt you can make it run with a 750.
