1988 F-350 Rear Brake Drums - Ford Truck Enthusiasts Forums
Old 06-11-2001, 08:40 PM
MeanOlBill MeanOlBill is offline
MeanOlBill is starting off with a positive reputation.
How do I remove the rear brake drums? Do I have to pull the axle?
Old 06-12-2001, 01:16 AM
whomrig whomrig is offline
whomrig is gaining momentum as a positive member of FTE.
Bill, yes you will need to pull out the axle(s) to remove the brake drums. should be eight bolts to remove that hold the axle, then there are two large nuts on the axle itself. They can be tricky to remove. These come out one at a time, and there should be a washer with a tab between the axle nuts. A shop manual would be a good idea before doing this so you will have correct torque specs for re-assembly. You may ned to adjust the brakes "down" so the drum will slide off as there may be a ridge on the drums. Good luck.
Wayne
e-mail
http://home.pacbell.net/whomrig
Old 06-12-2001, 11:37 AM
Thanks, Wayne,appreciate the assist. I've been trying to find a service repair manual (eBay and a few other sites) but so far have only found Chilton which I've never liked very well. I'm mostly puzzled by a couple of small clips on the outside of the drum, on the wheel studs, that give me the impression that the hub could be removed without pulling the axle. Any ideas??
Old 06-12-2001, 11:49 AM
Bill, you could be correct as my F-350 is a lot older. These clips were used to hold the drum in place during assembly. They are not necessary to replace. The best shop manual will be a ford manual. E-mail me if you like.
Wayne
e-mail
Old 06-15-2001, 02:15 PM
bulabula bulabula is offline
bulabula is starting off with a positive reputation.
Bill, maybe I'm missing something here, but I replaced the rear drums on big doolie last year and other than jacking the beast up, and having tires and lug nuts seemingly everywhere, it was a piece of cake.
My old drums slipped off easily without issue. No axle removal, no clips. I did have to back off on the brake shoe adjustment to allow the new drums to slide on.
Hope this helps.
Chris
'88 F350 XLT Lariat CC DRW/7.5l/C6/4.10
'93 Mustang LX 5.0l/T-5/3.55's/Flo's/pulleys/K&N/Synthetics
Nissan p/u (DC commuter)
Volvo 940
Old 06-17-2001, 08:13 PM
Thanks for all the responses - all the info is helpful. In this case, it turns out that what I initially thought was a leaking wheel cylinder, wasn't brake fluid; it was an inner wheel seal.
I've run (mostly) Fords all my driving/owning life, about 50 yrs., but this '88 has been a real pain - I have just over 80,000 miles on it and have had more problems and repairs than anything else I've ever owned; very discouraging.
Bill
'88 F-350 (diesel)
'52 F-600
'61 F-600
'69 3500 Tractor (diesel)
Old 06-20-2001, 09:47 PM
rattly1 rattly1 is offline
rattly1 is starting off with a positive reputation.
Some trucks came with Dana rears and some had a Sterling. The drums just slip off the Sterling and the hub and all has to come off the dana.
Old 06-21-2001, 12:12 PM
Guess I must have the dana, or else they are rusted fast - I tried to just slide them off, even made a 'puller', but finally had to remove the axles.
Thanks - Bill
Old 06-21-2001, 08:53 PM
wytfut wytfut is offline
wytfut is starting off with a positive reputation.
Rear drum brake adjustment gthbryce 1987 - 1996 F150 & Larger F-Series Trucks 25 08-14-2016 10:20 AM
Inboard Drum Brakes wintersg3 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-28-2014 09:51 AM
Brake drums on rear. Colin Bigdog Yarnton 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-13-2013 08:17 PM
47 1 ton Brake Drums pyleofsteele 1947 and Older Ford Trucks 2 11-28-2006 03:57 PM
96 F250 rear brakes cowboysoldier 1987 - 1996 F150 & Larger F-Series Trucks 4 09-25-2005 07:42 PM
Tags
1988, 1988f350reardrums, 350, 88, back, brake, drum, drumb, f350, ford, leaking, rear, remove, replacement, specs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
