f350 superduty brakes
I have a 1999 f350 4x4.I am having an ongoing problem with severe brake pull when loaded up.I have been thru all the rotor's,caliper's,replaced as needed,new brake lines,slider pins and seals,svere duty pads,good brake fluid,etc.When recently repaired its ok for awhile,then when loaded and using the brakes alot the pull starts up again.Any info would be appreciated.Thanx.
