Door ajar light stays lit
Old 05-25-2004, 02:16 PM
Bill4Kath's Avatar
Bill4Kath
Bill4Kath is offline
I've got a '02 X and when all of the doors are closed the door ajar light stays on, along with all of the overhead lights and running board lights. When you try to lock the door, it unlock about 2 seconds later. Anyone have this problem? Maybe the door strikers needs adjusting. Not sure.
Thanks.
Old 05-25-2004, 03:38 PM
Landyot's Avatar
Landyot
Landyot is offline
Do a search here on this website for "ajar." This subject has been touched upon many, many times. I'm sure you'll find some words of wisdom in the posts you seek.
Old 05-25-2004, 04:23 PM
Bill4Kath's Avatar
Bill4Kath
I found out that WD-40 will take care of the sticking switch in the door latch. Thanks for the post.
Old 05-25-2004, 05:52 PM
firstford's Avatar
firstford
firstford is offline
I found that electrode cleaner works really well, too, and won't attract dirt or dust.
Old 05-25-2004, 07:08 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
Those things seem to work for a while. The real solution is to replace the switch.
Old 05-25-2004, 08:09 PM
navstar's Avatar
navstar
navstar is offline
I sprayed mine with WD-40 and its working fine for the last 10,000 miles.
Old 05-25-2004, 08:49 PM
Bill4Kath's Avatar
Bill4Kath
I used both the Electrode cleaner and WD-40. Obsessed muuchhh!
Old 06-03-2004, 01:34 PM
3greenfordsagain's Avatar
3greenfordsagain
3greenfordsagain is offline
door ajar switch replacement
What's envolved in replacing the switch. Is it possible to just snip the wire so the door ajar switch is cut out of the mechanism?
Old 07-14-2004, 08:40 AM
markathi's Avatar
markathi
markathi is offline
I have a 2000, XLT, 2x2, V-10. My door ajar light also stays on when the door are shut. The dome lights and running board lights also stay on. I have had all door lock switches replaced because mine too were sticking or slow to open. Every time I make an appointment to take it in the light is out.
Old 07-14-2004, 03:24 PM
Landyot's Avatar
Landyot
Landyot is offline
I did the WD40 thing a year ago ... it works ... for awhile. Then I replaced all six door-ajar switches. Problem still surfaces occasionally (I think I was sold some of the older style switches ... mixed assortment of packaging among all six). I'm fed up with it, and am currently wiring in a bank of four toggle switches where I can disable the offending "door" whenever the light starts coming on again. The wiring is fairly simple once you've identified the correct wires on specific connection plugs attached to the G.E.M. on the backside of the fuse box (all the wiring I'll install will be accomplished under the dash). There are only four wires I'll need to splice into; LF door, RF door, rear doors, and lift gate.
If you attempt to pull the fuse when this problem occurs, be prepared for some other annoyances ... such as no electric windows, and cannot shift out of park.
Old 07-20-2004, 10:01 AM
heatmon's Avatar
heatmon
heatmon is offline
Question Door Ajar Lights
Landyot,
Aren't the Rear Door Ajar Switches the same as the Fronts? One Switch for each Door to make the total of switches\wires at least 5 (adding 1 for the Rear Hatch). Is it possible that there are additional switch(s) for Rear Hatch Doors & Glass (upper half)? I've looked at the wiring diagrams of that part of the truck only briefly- I'll have to go back & look again.
Old 07-20-2004, 04:06 PM
Landyot's Avatar
Landyot
Landyot is offline
(deleted) ....
Old 07-20-2004, 04:09 PM
Landyot's Avatar
Landyot
Landyot is offline
Heatmon - Yes, the rear door "switches" inside the doors are the same as the fronts, but they're connected as a pair by a single wire to the GEM. The front doors are connected to the GEM by two individual wires. The TWO switches on the rear liftgate (or "upper half" ... the lower barn doors have no switches) are connected by a single wire. So, there are a total of six door-ajar switches, but only four wiring connections at the GEM. I disconnected the battery, pulled out the fuse panel a short way, and then the C240a, C240b, and C240c connectors are easily accessible. I installed an array of four toggle switches (up under the dashboard, out of sight) so I can disconnect the offending door-ajar switch if .... no, make that WHEN it acts up again. In addition, I'll be able to isolate the problem to at least one pair of switches. Regardless, being able to disarm that annoyance will be the big relief. BTW, all connections were soldered, then insulated with heat-shrink tubing. I also included trailer-style disconnects in the event I ever need to disassemble that arrangement.
Does anyone understand why the above post won't let the word "battery" be included ... "I disconnected the battery, pulled ..." ???
Old 07-20-2004, 10:20 PM
heatmon's Avatar
heatmon
heatmon is offline
Landyot,
Gotcha. I mis-stated in my post that I didn't experience the problem with the door ajar warning lights again. It did happen once a few weeks ago- I got so mad that I went around the truck slamming all the doors shut. The light went off, but I guess I'll see it happen again some time. At that time I would do as you have, because I have no idea which door caused the problem. I suspect the tailgate door(s), but without a logical way to troubleshoot, it's anybody's guess. I wonder if this would show up in the computer error codes? Does anyone know whether the "Door Ajar Warning Light" produces a readable code in the OBD II computer? In the generic OBD II system or do you need a Ford specific reader to pull a code from a chassis electrical error? Would it show on a "Predator" or similar performance mod computer? Any help would be greatly appreciated.
Old 07-23-2004, 12:24 AM
TomRowe's Avatar
TomRowe
TomRowe is offline
Door ajar light on '02X
Just bought a 02 X limited 7.3L and the night wife took it home she noticed door ajar light and running board, interior lights say on for about 15 minutes after locking or closing doors. Will let you know what fixes the problem.
Tom
Quick Reply: Door ajar light stays lit
