Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-25-2004, 01:09 AM
f350diesel91 is starting off with a positive reputation.
Help - New to hydraulic clutches
I have a '91 F350 Diesel (International 7.3) that the clutch pedal has gone to the floor and stayed. I am unsure where to start looking for problems/replacement parts. Is this simply a master dylinder arrangement, and if so, what should I check? I don't believe that it dropped any fluid when it went, but am not positive.
  #2 (permalink)
Old 05-25-2004, 11:43 PM
Spectramac's Avatar
Spectramac is gaining momentum as a positive member of FTE. Spectramac is gaining momentum as a positive member of FTE.
Pull the lid on the clutch master, is it full? I would imagine the clutch is still released, right? If it still has fluid but won't build any pressure maybe it's gone bad.
__________________
Malcolm
97 Explorer 5.0 AWD
87 F250 6.9 CTS turbo
  #3 (permalink)
Old 05-26-2004, 07:53 AM
Yes, there is fluid in the master, but appears to be low. What type of fuid is recommended by Ford? If I fill the fluid and it still won't build pressure, then can the master be rebuilt or does it have to be replaced?
  #4 (permalink)
Old 05-26-2004, 12:22 PM
Checked the lower cylinder and the housing is broken on the end and the keeper ring fell out in my hand. Is this part of the master/hose/lower assembly as a unit only or can just the lower cylinder be replaced and re-bled? If not, how much should the whole assembly cost and are there any other options?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
