6.0L Stock Downpipe Removal - Ford Truck Enthusiasts Forums
Old 05-24-2004, 11:17 AM
resqdawg3's Avatar
resqdawg3 resqdawg3 is offline
resqdawg3 is starting off with a positive reputation.
Does anyone have a clear way of taking this DP off in under an hour? I'm taking my truck in on Thursday to get the new 4" exhaust put on, and I'm trying to save them, my installer, some heartache.
The last one they did, it took them 2 hours to get the DP off, they hate working on these rigs because of it. I have a few other 6.0 bretheren here that are wanting exhausts, but don't want to put our installer through the grief of a 2 hour DP removal process.....
Any hints, tips, tricks to making this easier will be greatly appreciated!!
Old 05-24-2004, 06:27 PM
macvtt macvtt is offline
macvtt is starting off with a positive reputation.
You can cut the downpipe with a saw or jack the trans and remove the crossmember. If you have the dp with the foil like insulation you can cut a small bolt that sticks out of the firewall to make the removal easier. (the bolt gets caught on the straps that hold on the insulation) 03 motors have the insulation, 04 motors do not. A 04 motor with the smooth dp can be done in a half hour with air tools. Hope this helps.
Old 05-24-2004, 06:50 PM
resqdawg3's Avatar
I have the 03MY truck. It has the foil on the DP. Now, where is this bolt you are talking about, and is anything going to be affected if I do hack it off?
Old 05-24-2004, 09:56 PM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
The key is removve the wrap as high as you can get to from under
cut all the foil bands so they can't hang on anything -
go as high as you can with the sawzall to cut the downpipe...
Your NOT going to reuse it anyway so to heck with it...
but do save the top part of the downpipe so you can see the massive difference between stock and a 3.5 or 4 inch downpipe !!!!!!!!!!!!!!!
Old 05-24-2004, 11:10 PM
resqdawg3's Avatar
I'm going to try and take some pics of the install on Thursday. I'm going with a 4" Mandrel Bent turbo back.
Old 05-25-2004, 12:54 AM
uponyou21 uponyou21 is offline
uponyou21 is starting off with a positive reputation.
Quote:
the stock one looks like a bent and crushed straw compared to the new one!!!
Old 05-26-2004, 12:10 AM
D HOOKER D HOOKER is offline
D HOOKER is starting off with a positive reputation.
I put in a Banks Monster exhaust last weekend and I had to cut the downpipe with a 4 1/2" grinder. Also bent that bolt on the firewall up as far as possible.
Old 05-26-2004, 08:17 AM
brad diesel brad diesel is offline
brad diesel is starting off with a positive reputation.
i put on the HOG 4" system last weekend, what a quality product for under $600.00.
sawsal the old system in sections,watch there video and go, couple of hours.
Old 05-26-2004, 10:04 AM
jdadamsjr's Avatar
This sites supporting partner, Motorhaven, had a group buy going on at a great price on exhaust... check it out to see if there are any more available...
they support this great site, so let's support them....
Old 05-26-2004, 12:15 PM
resqdawg3's Avatar
I'd love to support Motorhaven, but I just cannot pass up the deal that my buddy is offering me on this exhaust.....Trust me...it's cheaper than you think. lol
Speaking of which, he called me last night and told me that the 4" pipe that he was needing to connect the tail pipe section and DP never showed up this week. So, no exhaust for me this week. :sigh:
So, I think that I'll go get my window's tinted tomorrow instead, and order my Intake from Motorhaven! :woot
Old 05-26-2004, 01:06 PM
Nothing is affected if you cut the bolt off. If you get under the truck and look up at the dp you will see a bolt that sticks out into the space the dp goes through. When you unbolt the dp from the turbo and pull it down the straps that hold the foil to the dp get caught on the bolt. Hope this helps some. Oh yeh did you ask if the exhaust you are getting needs to have the firewall ported?
Old 05-26-2004, 03:03 PM
resqdawg3's Avatar
What do you mean, Fire wall ported?
Old 05-26-2004, 09:24 PM
The fire wall has a seam where two pieces come together. When you go to a 4in dp there is not enough space to fit the pipe without it resting on the seam. If the dp is touching anything you will get a vibration that is felt through the floor. I have a Hog system that I installed and I had to use a hydrolic tool called a port-o-power to flatten the seam for clearence. Go to www.hogperformance.com and watch the video clip on the install. I dont know if all 4in dp are like this but it does get real tight in there.
Old 05-30-2004, 02:05 AM
Tower Jack Tower Jack is offline
Tower Jack is starting off with a positive reputation.
on a 6.0 with a 3.5 inch DP porting isn't necessary. If you go for a 4 that may be another story
Old 05-30-2004, 10:29 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
Quote:
Is this the same on the Excursion
DP-Tuner F5 chip Pigman54 Ford Truck Parts for Sale 5 11-02-2014 09:02 PM
Time To Upgrade Exhaust 1L243 1999 - 2003 7.3L Power Stroke Diesel 19 03-09-2013 10:35 PM
DP Tuner and ZF6 manual question. westarms 1999 - 2003 7.3L Power Stroke Diesel 95 03-03-2011 06:35 PM
Died while driving, now no start. wadesmith 1999 - 2003 7.3L Power Stroke Diesel 18 03-14-2010 10:32 PM
cheap diesel chip and DP tuner jeffdoerr 1999 - 2003 7.3L Power Stroke Diesel 5 11-22-2009 09:22 PM
Tags
350, 4, 60, 60l, 96, downpipe, exhaust, f250, ford, pipe, powerstroke, removal, remove, replace, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
