Truck just quits
Truck just quits
Riding down the road Saturday night towing my boat home. Truck just shuts down going 50 mph. I'm not sure if it shuts down completely or just a temporary loss of power. When it shuts down the glow plug light comes on and the tow haul mode shuts off. The truck starts going again on its own. It happend 8-10 times in a 5 mile stretch. I made it home and Sunday morning I disconnected the batteries hoping to reset something so I could use my boat. It has only happened once since then. I should note it happened Saturday morning without towing the boat but at that time I wasn't sure what had happened. Anyone else have this problem? Any ideas?
I have contacted the service manager at my dealership. We are on a first name basis at this point. He said if the check engine light was not coming on it was probably not sending a code. The only thing he could do is take it for a test ride to see if he could duplicate problem. Since it is a random event that would be like playing the lottery. I am going to drive it for the rest of the week then let him hook it up to check for codes. Will see what happens.
*2004 truck with 08/03 motor.
it sure sounds like a ign switch problem. i suggest u take the under-dash fuse box cover off(the big panel w/ 4 plastic "screws") and w/ a 10mm socket, make sure the bolt in the middle of the ign connector is tight. the connector is white and up on the steerin column under the dash, and about 1.5"x3" w/ heavy guage wires comin out.
superduties have had a few problems w/ this connector
