Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-23-2004, 08:04 PM
79 Trailer Special's Avatar
79 Trailer Special 79 Trailer Special is offline
79 Trailer Special is starting off with a positive reputation.
Angry Fluidamper problem
I just got my 351M into a 400 engine back from the builder and ran across a problem while installing it. The rotating assy was balanced and he used a Fluidamper tyoe of balancer which is fine by me but.....The stock balancer has a hub that comes out of the front of the damper that the bottom pullys sit on and then are bolted in place. The Fluidamper does not have this hub so even if I put the 4 bolts on the pullys can wiggle about 1/16". Also the back of the pully is recessed a bit so it does not sit flat on the aftermarket damper, there is about 1/8" gap between the two. Anyone else run across this and if so what was the fix?
Thanks in advance, Rick
__________________
They call me Rick....along with a few other names I cant repeat
I'll keep my guns, my freedom and my money, you can keep your "change"
  #2 (permalink)
Old 05-24-2004, 07:01 PM
danlee's Avatar
danlee danlee is offline
danlee has a good reputation on FTE. danlee has a good reputation on FTE.
I am using a Fluidamper (Streetdamper) on my 400, but have had no problems like you mentioned. I had the stock pulleys on for a while, now I have March Aluminum Serpentine pulleys.
  #3 (permalink)
Old 05-24-2004, 07:41 PM
Thanks for the reply danlee. I checked with the builder today and he called the manufacturer. There is a hub assy for mounting the pullys that was missing from the box. It should be here by 10 AM Tuesday.....hopefully.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
