Bronco Windows
Are the motors completely shot, or are the nylon spacers inside shot? You can get "gear replacement kits" from O'Reilly's for $15 - $3 core or you can actually replace the spacers with fishing weights...
When you press the switch what happens? Does the motor try to turn at all? Is power getting to the switch? Is power getting to the motor? Can you hear the motor turning, but the window doesn't go anywhere? Can you hear the motor trying to turn but locking up?...
Watch your battery gauge while you try both windows with the engine running. If you see the gauge move, then the power is getting to the motor.....it could be jammed. If it just doesnt have the "uumpf" to get the window back up all the way, remove the motor and inspect the insides. If the 3 nylon washers are shot ( ground to pieces inside ) then there are numberous posts about how to fix this issue.
Best bet is to get the motors yanked out, and tell us what you find.
fordtrucknut
37
02-05-2009 04:19 PM
