7.3 sluggish - Ford Truck Enthusiasts Forums
7.3 sluggish
Old 06-02-2001, 10:31 AM
Free9798 Free9798 is offline
Free9798 is starting off with a positive reputation.
7.3 sluggish
1991 F-350 Dually Crew Cab 7.3 (not power stroke). 82500 miles
Runs good most of the time but a bit sluggish then occasionally it will have a smoothe and powerfull surge this will last for a few miles. It then returns to it's usual sluggish self.
I change oil, filter every 2500 and fuel & air filters every
3000-5000. MPG 10-12. Any help is appreciated.
Old 06-02-2001, 10:53 AM
powerstroker250 powerstroker250 is offline
powerstroker250 is starting off with a positive reputation.
7.3 sluggish
Injection pump maybe?
Les
Old 06-02-2001, 04:37 PM
The Diesel Dude The Diesel Dude is offline
The Diesel Dude is starting off with a positive reputation.
7.3 sluggish
I agree with Les. The injection pump was the weak link on that engine. They usually needed to be rebuilt (you can buy a rebuild kit for them just like a carburator) about every 70,000 to 100,000 miles.
Old 06-05-2001, 11:11 PM
cpdjr cpdjr is offline
cpdjr is starting off with a positive reputation.
7.3 sluggish
Who offers a rebuild kit?What about internal calibrations in the
pump?
Old 07-10-2001, 01:03 PM
logan_85 logan_85 is offline
logan_85 is new and has a neutral reputation at this point.
7.3 sluggish
Old 09-23-2001, 06:07 PM
redneckdieselmechanic's Avatar
redneckdieselmechanic redneckdieselmechanic is offline
redneckdieselmechanic is starting off with a positive reputation.
7.3 sluggish
put a bottle of mystery oil in the fuel tank. It sounds to me like the injectors are clogged up. Or try higher quality diesel or cetane booster. Try the easy stuff before the harder stuff.
Old 09-23-2001, 06:08 PM
7.3 sluggish
I say to put a bottle of mystery oil in the fuel tank because it helps to unclog the injectors and also clean out the injector pump. Many truckers I know use the stuff and it works.
Old 09-29-2001, 08:35 AM
hal283 hal283 is offline
hal283 is starting off with a positive reputation.
7.3 sluggish
Do you mean something like Berryman B-12?
My wife and I are testdriving a '95 F-350 (7.3L powerstroke), and it seems to almost stall at times. It has actually died a couple of times at intersections, etc. Mostly I'm concerned with the loss of power on the road. It is hard to describe, but it is like the injectors stop working for a couple of seconds.
Any thoughts on that?
The truck appears to be in great shape and it only has 52000 miles. According to the dealership, a couple used it as a ranch truck, but decided to trade it in for a Dodge.
Old 09-29-2001, 06:08 PM
argve argve is offline
argve is starting off with a positive reputation.
7.3 sluggish
Stanadyne Performance formula works great. The stalling is from the diesel fuel being so dry ( poor quality ). Dump a bottle in both tanks each, and it will work wonders... The performance formula will also boost the cetane rating, and lower the gel point. I can't really say enough good things about it.
1991 F350 CC Dually 7.3l, E40D, Soup bowl removed, K&N
Rough Idle,sluggish scotty088 6.0L Power Stroke Diesel 3 06-24-2014 12:45 PM
02 7.3 very sluggish first few miles nickt916 1999 - 2003 7.3L Power Stroke Diesel 7 10-27-2012 04:34 AM
7.3 sluggish and noisy on take off Edfromgeorgia 1999 to 2016 Super Duty 3 11-25-2009 03:52 PM
Help A Female rvingaz New Member Introductions 1 10-11-2007 05:55 AM
Driveability - Sluggish on Take-off 1997 7.3 PS stereokarter 1994.5 - 1997 7.3L Power Stroke Diesel 3 12-13-2005 09:25 PM
Tags
1991, 1999, 2000, 350, 73, 97, bowl, clugged, diesel, ford, fuel, powerstroke, sluggish, tank, turbo, unclog
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
