Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-23-2004, 09:24 AM
Steve_B's Avatar
Steve_B Steve_B is online now
Garage is empty, add now
Steve_B is gaining momentum as a positive member of FTE.
Cam Question
I,ve been taking a closer look at my flathead V8 and found a few interesting things
1, I have a 4" stroke
2, I have adjustable lifters
I am wondering if I have a standard cam, I measured the valve lift and both inlet and exhaust are .310", Dose anyone know what the standard cam lift was
The engine was built in Canada model C1BA
  #2 (permalink)
Old 05-23-2004, 05:32 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.
I believe the Stock Ford cam for 49-53 was about .296.
__________________
Dick C
Erie, PA
1948 Ford F1 Panel
1952 Ford F2 (Non-Stock Flat 6)
1997 Ford Explorer
Every Thing I've Ever Said Is A Lie
  #3 (permalink)
Old 05-24-2004, 04:28 PM
51dueller's Avatar
51dueller 51dueller is offline
2003 Ford Explorer Sport Trac
51dueller is gaining momentum as a positive member of FTE.51dueller is gaining momentum as a positive member of FTE.
If you have the timing cover off the engine. Look at the front of the camshaft. It should say EAB-A or 8BA-B. If it doesn't you don't have a stock ford camshaft. This only applys to the 49-53 engines.
__________________
Nathan
You may have an Effie but I have a Emmie! TM
'51 Mercury M-3 Extra 5 Star Cab Dually "Faith"
5.4L, AOD, Dana 70 3.73:1, Twin-I-Beam
Built to play and work hard!
  #4 (permalink)
Old 05-25-2004, 02:02 AM
Overkill-F1's Avatar
Overkill-F1 Overkill-F1 is offline
Overkill-F1 is starting off with a positive reputation.
My '52, C1BA/8RT has a EAB-A cam, .328" lift. ...Terry
  #5 (permalink)
Old 05-28-2004, 11:49 AM
Steve_B's Avatar
Thanks guys
I checked the cam and it's marked 8CM, maybe a Mercury cam ?
Stephen
  #6 (permalink)
Old 05-30-2004, 09:36 PM
51dueller's Avatar
Yes that is a mercury cam. I forgot about this one. The other numbers I listed are for the Ford engine.
__________________
Nathan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
