Automatic door locks
I think it may be a vacuum operated trigger for the locking to occur. Sometimes mine lock right away, and sometimes it takes a little bit of driving.
As far as equipment packages go, could it be part of the Advanced Security Group? Black99GT, does you 99F350 not have the keyless entry where your 2000 Ex is equipped with keyless entry? My old 2002 F-350 Lariet had the automatic locking feature and both my current truck also do, but they also all had keyless entry systems.
I had a factory accessory keyless entry installed on my '04. I got a copy of the installation manual too. The accessory keyless system can be programed to autolock if you want. You have to play with the ign key and the valet switch to get into options mode. I would bet all the Code System units can be programed similarly. As a matter of fact, the guy who installed my system said the instructions were the same for mine as the older models.
I also have an older grand marquis, it has a keypad in the door, but no keyless. The owners manual has a "dance" you can do with the combination keypad to turn the autolocks on and off. Maybe the expy's have the same system?
Originally Posted by Greg250
If you don't have factory installed keyless entry, it won't do the auto-lock thing. Most aftermarket remote starts/ keyless entrys have that feature built in so it would not be a big deal to get it
