Tire Pressure Sensor Warning On 2004 Expedition
Originally Posted by LUNGFIXER
NOPE...same thing happened.
Don't select it and your image should appears PROVIDED that the site that is hosting pics allows you to post pics elsewhere.
See?
Take webmaster's advice, however, and load them up into your FREE gallery and post the pics from there. It is better for the other users.
Hey guys, I JUST might have a fix for this resetting thing...
I just need to know what procedures you go thru to reset the wheel sensor. Like do you start the car, wait a few secs, press the button, then drive, I mean cruuuuise down the street? And this needs to be done (pressing the button) everytime you start the car?
If that's the case, I probably got a fix for it! My brother has a 04 but stock wheels but I'll see what's the scoop on that is. I have an 01 with 20" Irocs (that I'm looking to sell!)
Anyway, let's get to work!
Sean
Sean
From what I was told the sensors are on the stock tire rims which are in my garage. I suppose one could take the sensors off the stock tires and put on the new tires, but who is to say this will work if not installed properly? Then again, when time to replace worn tires then this must be done or you will get the irritating mesesage. Maybe they will not work if installing the sensors on larger tires. I don't think Ford even knows.
phoneman91
32
08-21-2013 08:37 AM
brucecassida
07-17-2013 06:34 AM
