Doug Nash Overdrive Advice? - Ford Truck Enthusiasts Forums
Old 05-22-2004, 07:10 AM
banjopicker66 banjopicker66 is offline
banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.
I have obained a Doug Nash overdrive unit for my C-6. It has the tailshaft housing and the OD unit, but not the wiring, the relay(s) or the switch.
1. Can I obtain a suitable replacement? (anyone got an original set for sale?)
2. Where can I obtain a wiring diagragm? I can probably wire one up if I have the right schematics.
3. Any advice is appreciated.
Old 05-22-2004, 08:54 PM
SoCalDesertRider SoCalDesertRider is offline
SoCalDesertRider is gaining momentum as a positive member of FTE.
Not sure on this, but I have heard that the US Gear overdrive unit is a mutation of the old Doug Nash unit. Might want to give US Gear a call.
Found a c6 gear vendor and DN overdrive jayro88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 23 07-06-2014 12:39 AM
Doug Nash / US Gear Overdrive Units pm042070 Clutch, Transmission, Differential, Axle & Transfer Case 2 09-25-2013 01:55 PM
Dne2, Doug Nash underdrive problem robert7249 Clutch, Transmission, Differential, Axle & Transfer Case 1 06-25-2012 11:31 PM
Doug Nash Overdrive unit lewismohr Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 09-20-2010 07:13 PM
Doug Nash Overdrive Unit Question Ford79 Clutch, Transmission, Differential, Axle & Transfer Case 5 10-20-2008 03:53 PM
Tags
4x4, doug, drive, f150, ford, gear, nash, overdrive, sale, schematic, shmatic, unit, units, wireing, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
