You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
It is ok as long as you use duel fuel for cng...the tanks that come on the trucks only have a range of about 100 miles...and you can't just fill them anywhere...plus it is getting to be expensive....plus the cng conversion runs about at least 3500 bucks...propane is running over 2.00 a gallon plus you have to buy an alternate fuel use permit that runs about 250 bucks a year...propane kits run about 1500 bucks...plus the mileage isn't as good as gasoline...on good thing is you don't get dirty oil and the plugs last longer...our company had propane on all of our trucks and cars...it was cheap for us because we were paying about $.45 per gallon because we were a large gas company...we even had some GMC' on cng that we were trying out for Gm...they lasted about 6 months...we were using them on primarily on cng but when they went to use gas they had to change all the fuel injectors....plus range with the tanks with 3500psi (full) they only got from 70 to 80 miles between fill ups...no practical...even for a gas company....rather have my diesel....Ford does have Cng conversion for the Crown Victoria and I believe propane may be availible on the larger trucks...
As for special mods for engine there are none...it the truck runs unleaded gas they are capable of running propane or cng...you only need a reg to convert the propane from liquid to vapor...cng is a vapor already....
__________________
'04 F-250 6.0L CC LWB 2WD Lariat Born 10/14/03
List Mod's in Gallery
FTE
I have seen Fords in California use alternative fuel so I know the option is out there. I just don't know where to get the conversion. Also the fuel is getting to be just about as expensive as the regular fuel you put in so what is the point.....
__________________
Current Vehicle
2008 F350 Crew Cab Long Bed 6.4L
H&S Mini Max, DPF Delete and Downpipe, Banks CAI
Past Vehicle
2004 F350 Crew Cab Long Bed 6.0L
Banks 4" Monster Exhaust w/Six Gun
The bus company in Austin, TX had big stickers on some of their buses saying "Clean burning alternative fuel - Propane" or something like that. Turns out they were running diesel all the time.
__________________
2009 Explorer Eddie Bauer 4.0 V6 4X4.
Previous:
2005 Nissan Xterra 4X4
2003 Ford F250 6.0 Powerstroke 4X4
1986 Ford Bronco 4X4
