Propane take for Powershot2000
Old 07-19-2004, 02:42 PM
SoundBuys's Avatar
SoundBuys
SoundBuys is offline
I just purchased a Powershot system used and we are having problems shipping the tank. So I may be looking for one local. What tanks are prefered? Can I use a standard grill propane tank, I thought someone said that I can but I would have to get two of them.
Any help would be great!
Shawn
Old 07-19-2004, 03:25 PM
Quadzilla's Avatar
Quadzilla
Quadzilla is offline
Using BBQ tanks is fine, but you will need two of them to supply enough vapor during "Happy Hour". One would be sufficient for steady freeway cruising, but I'd guess that ain't why you bought the system, eh?
I've got a 9.9 gallon Manchester tank mounted under the bed, and that's a great permanent setup. I can easily go 2500 miles between fillups of the propane tank, and I have my system wicked up.
Contact Dale Isley at TYMAR for one like mine. He can probably get it shipped to you.
Old 07-19-2004, 04:15 PM
SoundBuys's Avatar
SoundBuys
How much was your tank? Also for compairsion how big is a grill tank?
Shawn
Old 07-19-2004, 06:47 PM
bigdieseldav's Avatar
bigdieseldav
bigdieseldav is offline
I would suggest setting it up like quadzilla, and I intend to do the same thing, but in the mean time i run the two tanks in my toolbox. Pics are in my gallery. They are 2 1.5 gallon pancake tanks. I filled them up about 2 months ago and they are still not empty.. I only use my propane upon spotting an unsuspecting dodge. So i figure my set up is good for now. Quad has a awesome truck doesn't he!!?
Old 07-19-2004, 09:33 PM
SoundBuys's Avatar
SoundBuys
I would love to get a larger tank and if I can find someone to ship the used one I was looking at that would be a big help. If not I may just do a dual tank setup.
Do I need any aditional hardware to hook the two tanks up? If anyone has specifics on how to hook it up that would be a big help.
I just cant wait to get everything installed. The system I got also came with a superchips programed for the propane, I also ordered a 4" turbo back exhust.
Old 07-19-2004, 10:54 PM
bigdieseldav
you can go to any LP shop or service station and have them rig you up a dual tank set up. Mine cost about 20 bucks for the hardware to connect them. You can do it cheaper, but i had mine done right!!
Old 07-19-2004, 11:13 PM
bigdieseldav
BTW, don't hold your breath about them sending the tank, I doubt they will send it to you. I spent about 6 months trying to get them to send a small r/c airplane engine to Tennessee. It didn't happen. Legally I don't think they are allowed to ship anything that has/had any type of flammable fuel in it. Good luck though
Old 07-20-2004, 07:58 AM
SoundBuys's Avatar
SoundBuys
You have any details of what they used for the connections?
Old 07-20-2004, 08:45 PM
Quadzilla's Avatar
Quadzilla
When rigging up two bbq tanks, all that's needed is a "Y" hose, one that connects to both bbq tanks, and feeds into a single outlet.
The cost of my tank was around $300.
Old 07-20-2004, 10:42 PM
t.j.g.'s Avatar
t.j.g.
t.j.g. is offline
look for a used propane tank from an rv
Old 07-21-2004, 04:40 PM
Quadzilla's Avatar
Quadzilla
That's a good idea, but also pick up the date of manufacture of the tank. Some jurisdictions won't allow a tank to be refilled that has been in service for too many years.
Old 07-21-2004, 05:54 PM
SoundBuys's Avatar
SoundBuys
Thanks for all of the info guys. I am still trying to get the one shipped to me. I am also looking around where I am to see if I can find a used or new one.
Old 07-22-2004, 10:54 AM
troutnut1's Avatar
troutnut1
troutnut1 is offline
Tank buyers should also be aware that newer style OPD (overfill protection device) valves are required in most locations for you to get these tanks refilled. Older tanks without these newer valves can usually be retrofitted with the new valves and pressure tested and stamped with a new date by your local propane supplier, but of course this costs money. I had two done for my RV like this not long ago and I can't remember how much it was, though it was considerably cheaper than new ones. The older valves usually are kinda round while the newer valves are always triangular and stamped OPD on them.
Hope this helps!
Old 07-22-2004, 06:02 PM
Quadzilla's Avatar
Quadzilla
Good point.
VLLC
01-17-2014 07:13 PM
brentos
05-19-2008 09:03 PM
rockcj
10-09-2006 07:20 PM
SoundBuys
Bio-diesel, Propane & Alternative Diesel Engine Fuels
11-05-2004 11:27 AM
bigdieseldav
06-04-2004 08:45 PM
Quick Reply: Propane take for Powershot2000
