How much CFM do i need?
With electrics, more is always better. The dual fan set up is pricey but it also moves the most air. Installing a single fan will work dependening upon your application. Be careful with the ones that zip tie through your rad. If there is any play they will eventually cut through it.
If you have room, you could always a install a puller on the inside and a pusher on the outside of the radiator.
gingerbreadmaniac
08-26-2015 11:18 PM
IHF250fireman
30
08-15-2015 08:07 PM
HogTied
17
06-11-2006 06:34 AM
