2004 F350 4x4 trouble!!!!!!!!!!!!!!!
I'm having a similar problem. F250, 6.0 diesel.
Hubs on auto....no change with SOTF turned from 2x to 4x. Operates as 2WD either way.
Hubs on Manual...2WD on the SOTF dial...operates as 2WD.
HUBS On Maunal...4WD on the SOTF dial....operates as 4WD with loud grinding.
What in the heck is going on?
Fairbanks here, btw.
sounds like your 4x4 is engaging properly, but dirty or bad hubs may be causing the grinding if you only hear it with the hubs locked and in 4wd
51dueller
104
03-08-2024 04:09 PM
fastman35
13
11-27-2016 09:24 PM
GaryKip
35
03-14-2016 12:03 PM
