Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine
  #1 (permalink)
Old 05-17-2004, 02:48 AM
Toreador's Avatar
Toreador Toreador is offline
Garage is empty, add now
Toreador is starting off with a positive reputation.
Question What's the difference between 3.55 axle ratio and 3.73?
Excuse my ignorance, but what is the difference between the 3.55 axle ratio and the 3.73 axle ration? Does the 3.55 ratio have a tighter turning radius and better handling? And what is "limited slip rear"? Thanks for any input.
  #2 (permalink)
Old 05-17-2004, 07:19 AM
ctfordguy ctfordguy is offline
ctfordguy is starting off with a positive reputation.
Axel ratio is the number of revolutions the driveshaft make compared to the rear axle. In your examples the drive shaft would turn 3.55 or 3.73 times for each rev of the rear tires. Finally the lower the number the less engine revolutions needed for a given speed, better gas mileage. Higher the number better pulling power. That is why the HD come with 4.10.
Limited slip describes the differential. When you go around a turn the tires travel at different speeds because the outside tire has further to travel. The differential allows the tires to travel at the different speeds. In a open diff if you lose traction to the rear wheels only one wheel will spin. In a limited slip if you lose traction both wheels will spin.
__________________
08 F250 4X4 SCAB 8' Bed
Lariat Trim level
6.4l Diesel
  #3 (permalink)
Old 05-17-2004, 07:22 AM
ScrewBuddy ScrewBuddy is offline
ScrewBuddy is starting off with a positive reputation.
Very, very simply - a higher number will give you more low end pulling power (better acceleration), and lower top speed, and, theoretically, less fuel mileage. Limited slip prevents one wheel from turning faster than the other (e.g. - spinning in mud or snow), causing the vehicle to lose traction and turn to one side.
  #4 (permalink)
Old 05-17-2004, 12:42 PM
bigjack's Avatar
bigjack bigjack is offline
bigjack is starting off with a positive reputation.
0.18...........
__________________
2004 FX4 SCrew Dark Shadow Gray, 5.4L 3V
1990 XLT Lariat Red, 4.9L, Auto od. 264k mi.
  #5 (permalink)
Old 05-17-2004, 06:59 PM
Toreador's Avatar
Thanks, guys. To see if I get it. The 3.55 will give me better gas mileage and the limited slip will give me better traction in stuck situations. I guess that would be a good feature to have. Almost acts like a minny 4x4.
  #6 (permalink)
Old 05-17-2004, 07:41 PM
1956MarkII 1956MarkII is offline
1956MarkII has a very good reputation on FTE.1956MarkII has a very good reputation on FTE.1956MarkII has a very good reputation on FTE.1956MarkII has a very good reputation on FTE.
We do not order any 4x4 for stock without the limited-slip. It's our feeling that you really don't have true 4WD unless you also have a limited-slip diff.
__________________
Empower The Public, Pay It Forward
  #7 (permalink)
Old 05-18-2004, 06:07 PM
markus markus is offline
markus is starting off with a positive reputation.
Questions about Limited Slips - my friend at work recently bought a Chevy with the limited slip and complains it only works below 20mph or so. That above 20mph it acts like an open differential. Does the unit Ford uses have a similar feature?
  #8 (permalink)
Old 05-18-2004, 10:36 PM
baja_stx baja_stx is offline
baja_stx is starting off with a positive reputation.
Quote:
You can't really place a speed on the feature unless the differential has some type of actuated locking mechanism. The new F150 does not have any such actuator. With a limited slip one rear tire can still spin independently of the other. The two rear tires are basically held together to spin at the same speed by clutches... these clutches with enough torque can slip allowing one tire to spin at a different speed of the other. That's why they're called "LIMITED" slip.
Some people don't like limited slip. For example... if you're driving along in 2WD and hit a patch of ice with a LS rear axle then both rear tires will break loose. If your rear tires are spinning then the rear end of the vehicle want to move to the front... causing a spin out... an accident.
If the same thing happens to a truck with an open diff. then only one tire will start to spin. The other tire will just roll. Believe it or not having one rolling tire is better than having two spinning tires. It is MUCH less likely for a truck with an open diff. to spin out in 2WD.
The same concept holds true when performing a burnout or peeling out. A truck with LS will break both rear tires loose and you'll have to slightly steer the wheel to keep the truck from doing a donut. A truck with an open diff. will only spin one tire and will just go straight.
If both of your rear tires are rotating faster than the front tires then the rear of the vehicle wants to spin around to the direction of travel.
I'm not saying LS is bad. I get all my trucks with LS. I'm just stating that it has it's disadvantages as well.
__________________
Please take those stick on non functional ram-air vents off your vehicle!!!
  #9 (permalink)
Old 05-19-2004, 06:03 AM
baja,
The reason the truck will spin out with a limited slip is with both tires spinning there is obviously no traction at the rear. With no traction the rear will go to the easiest place, usually down hill(crown of road) or to the outside if in a turn.
__________________
Lariat Trim level
6.4l Diesel
  #10 (permalink)
Old 07-13-2004, 11:37 PM
EGCoach EGCoach is offline
EGCoach is starting off with a positive reputation.
I bought a 2004 xlt with the 5.4 ,4x4. I occasionally go off-road ( dirt, snow or a little mud). I got the regular differential. Will my regular differential fill my needs or should I consider an after-market diff.?
  #11 (permalink)
Old 07-14-2004, 12:39 PM
gmcplus03 gmcplus03 is offline
gmcplus03 is starting off with a positive reputation.
this is my first truck with a limited slip rear diff, 04 fx4 scab 4x4 3.55LS. ive had two rangers prior (01, 03 4.10 rear end) among other older full size f150's without limited slip. i always did ok offroading or even on a sloppy gravel road. the thing to remember is that reguardless of what rear end or vehicle you have, the vehicle will only do so much. if you get in to deep beyond the vehicle capibilities, you will get stuck.
  #12 (permalink)
Old 07-14-2004, 02:43 PM
grey77 grey77 is offline
grey77 is starting off with a positive reputation.
All good answers (above), but don't forget that the gearing is relative to the size tire your are using. As mentioned above, the 3.55 will give better gas mileage over the 3.73 for a given tire size range. Get above this range, say for 3.55 gears, and the performance will suffer, as well as putting additional strain on the tranny, gears, etc.
Didn't mean to complicate the issue, but you really can't talk gearing without mentioning tire size, and effecting the RPM's. The "higher" gearing number (ex. 3.73 vs. 3.55) will allow for larger tires that will come close to offsetting the RPM diff.
Use a gearing calculator - knowing the size tires you want to run and how you will use the truck (100% hwy, 50/50 hwy/off-road, heavy hauling, etc.) you can either pick the Gearing or Rpm and calculate the other (Rpm or Gearing).
  #13 (permalink)
Old 07-16-2004, 11:07 PM
Mojave2k Mojave2k is offline
Mojave2k is starting off with a positive reputation.
Quote:
In the case of one or both tires braking loose (as in hitting black ice) it would be the driver that easies off of the throttle to control the wheelspin. In all other traction situations.. snow, sand, mud, ect. with limited slip some of the traction would go to the wheel that has some. With the open differential one wheel is spinning, and digging a hole and you are calling a tow truck. Another advantage of a limited slip differential is that the spring loaded clutch pack pre loads the carrier and cuts down on slop in the rear end, saving sudden jerking loads on the gears under stressful situations.
__________________
Mojave2k
Last edited by Mojave2k; 07-16-2004 at 11:48 PM. Reason: Trying to get the quote right
Tags
2001, 355, 373, 392, 411, axle, clutch, difference, end, f150, ford, limited, mileage, pack, ratio, rear, regular, slip
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
