'91 Ranger dies/starts/dies at random while driving
#31
#33
Originally Posted by GeoMan
My bad... I meant the two ignition coils... Are they grounded through the mounts as well?
On edit: Thinking about it, I would have to initially say "no", the ground cannot be through the mounting holes, since a ground "switch" is what operates the coils, opening and closing the primary circuits, causing the secondary coils (and hence the spark plugs) to fire.
This is a quote from the DIS/EDIS article I posted a link to above, which is applicable to your 2.3L DIS system:
Spark is generated as follows: an electronic switch-to-ground is employed in the coil primary circuit. When the switch is closed, battery positive voltage (+12v) being applied to the primary circuit builds a magnetic field around the primary coil. When the switch opens, the power is interrupted and the primary field collapses, inducing high voltage in the secondary coil windings, causing the spark plugs to be fired.
#34
Thanks for the replys. In either case, I made sure the mounting area and the screws were clean before I re-installed the coils and the DIS. Much to my dismay, though, after everything was said and done, I had inspected and cleaned virtually EVERY electrical connector I could locate, I un-bolted and cleaned every engine-to-body ground I could locate, and the condition STILL exists!! (ARRGHHH...). So now, I think I am convinced the condition posted at the top of this thread is caused by a fuel delivery problem - either too much, or not enough. Now, when I start the engine, it runs fine at idle, but any quick acceleration (still in park) it boggs and nearly dies - until I back off the accelerator, then it's back to idelying fine. ALSO... Seems to be running quite lean - the smell is obvious. Would a bad fuel pump cause the problem? What about a bad fuel punp relay? Or the fuel filter? ANY MORE IDEAS? ANYONE??
#36
#37
Your best bet would to put a fuel pressure guage on it and rev the engine. Watch the fuel pressure, if it drops then look for the problem. If that is ok the look for an electrical problem. Have you replace the the PCM power relay? That would explain no error codes, also if the fuel pressure was dropping I would think you would get some error codes, Lean cly, o2 sensor etc. Also, do you get any dash light flashes when it stumbles?
Dave
Dave
boggerted
07-14-2017 12:10 AM
trouble_truck_guy
2004 - 2008 F150
01-15-2013 03:03 PM
mattmesa
1983 - 2012 Ranger & B-Series
17
06-10-2012 02:19 AM
ctfl
04-16-2012 10:54 AM
