Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2004, 06:12 AM
Spktyr is new and has a neutral reputation at this point.
Running rich/overfuelling?
Recap: 86 F-150, 302 w/EFI, AOD.
This thing has a problem with running very rich - not to the point where it generates a black cloud of unburnt fuel, but you can definitely smell it. Here are the symptoms:
Hard to start - must depress throttle slightly (thus allowing more air in) to get it to start more easily. I say more, because it takes at least three or four tries of 3-5 seconds to get it started - or more.
After started, raw gas smell evidenced from exhaust. Idles at ~1500 or so, but drops down to 5-600 within 3 minutes. After running for about 5-7 minutes, idle will start oscillating between 5/600 and 200 or so and will eventually die unless a little extra throttle is applied. Even if throttle is depressed and engine allowed to run until it reaches normal operating temperature, it still smells like its running rich.
I haven't pulled codes yet, but I was wondering if there is a common failure point for EEC-IV on these engines. I'm also wondering if anyone has a map to the sensors and the test procedures for them; I am very familiar with the "classic" Bosch injection systems from D-Jet to Motronic and this is new territory for me. It's not immediately obvious where they hid all the sensors on this engine.
I'd also like to comment that none of the manuals I've collected for the truck to date have ANY useful info on this matter except for a list of how to pull and interpret codes. No sensor locations, no test procedures, nothing. Thanks a lot, Chiltons.
  #2 (permalink)
Old 07-17-2004, 10:29 AM
jcald6965 is starting off with a positive reputation.
Im having a similar problem but my truck has the black cloud of smoke choking anyone within a 100ft radius lol. I have the Haynes manual for my truck an 86 F150 with the 302 EFI and it has been helpful some what. I still have the smoke out of the tail pipe but it has the information you are looking for..
  #3 (permalink)
Old 07-17-2004, 10:42 AM
bremen242's Avatar
bremen242 is gaining momentum as a positive member of FTE.
that is common to not give sensor locations. My haynes manual seems to give more info on that. I have both- each of the manual have good info in them.
First thing I would do is pull the vacuum hose off of the fuel regulator and check to see if there is gas in it. That is the first common problem to a super-rich condition. The diaphram breaks in the regulator and dumps fuel into the intake through the vacuum hose.
__________________
http://mav.wastegate.net
'00 in the drive, '85 F250 that runs, '84 F150 in the weeds, minus 1 '85 F150- I finally got rid of some junk..
  #4 (permalink)
Old 07-17-2004, 01:12 PM
Actually, I figured it out - replaced the air charge temp sensor, the coolant temp sensor, and the O2 sensor. Seems to have helped.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
