I have a 1970 F250 Camper Special, 360 2bbl Holley. I went from 7.4 mpg to 9.6 after carb re-jetting (went from #73 jets to #65), a rebuild and a 6.5" power valve. I have a C-6 and 3.54 limited slip diff.
When I had the Holley 600cfm 4-barrel on my truck, it got 15mpg. I recently installed the Holley Commander 950 TBI 700cfm fuel injection; mileage is to be determined.
The rest of my truck is as follows:
360ci FE
Hedman headers
dual exhaust
C6 automatic with valve body shift kit
3.73:1 rear end ratio
does anyone know if the motorcraft main jets in the 2bbl 2150 carb are standard size and what are there size i can only find hollys can i use holly jets in my carb my carb is a motorcraft
