1961 F-500 swap in the 4.9L or the 5.9L??
Old 05-14-2004, 10:08 PM
JSMConstruction's Avatar
JSMConstruction
JSMConstruction is offline
I want to up grade this F-500 as it is going to Remain On my fleet for a Good many year's..I'll be hualing 2-4ton's on averag with this truck.
Stock drive line:
223-I6,4spd trans,5.45 gear's,and 7.50-20's.
Drive line option 1!:
300-I6,4spd,5.45 gear's,and 9.00-20's.
Drive line option 2!:
Built 300-I6,5spd OD trans,5.45gear's,and 9.00-20's.
Drive line option 3!:
5.9L Turbo Diesel,5spd OD trans,5.45 gear's,and 10.00-20's.
Old 05-23-2004, 04:37 AM
JSMConstruction
Talking
well i see this post get';s alot of View's but no reply's......
Wake up all you MD & HD truck lover's i need help.....
Old 05-23-2004, 06:43 PM
Dealford's Avatar
Dealford
Dealford is offline
Driveline option #4: 7.3 & 5spd OD .
Old 05-23-2004, 07:29 PM
fordinlinesix's Avatar
fordinlinesix
fordinlinesix is offline
Def. use a 5-speed, it will help the motor pull the weight around a lot easier. As far as having a reliable engine, you can't go wrong with either the 300 or the 5.9, but I would use the 300, it would be easier to keep cool and easier to drop in than a Cummins.
Old 05-23-2004, 08:04 PM
JSMConstruction
I didn't have the 7.3l as an option unpurpose.
I dislike V-8 Diesel's..........
if it ain't an inline6 turbo diesel i won't touch it.
But thank's for your input......
Old 05-23-2004, 08:07 PM
JSMConstruction
I'll prolly throw a beefed up 300-I6 in it for now then upgrade to the cummins when i have more momey and time.........
unless the 223-I6 hold's long enough then i might just swap in the diesel.......
But i will altimately run the diesel.....
it's just a matter of when.
i just would like to know what all in general what i might need............
Old 01-05-2005, 06:18 PM
peterbilt379exhd's Avatar
peterbilt379exhd
peterbilt379exhd is offline
My vote would sure be for that Cummins. That is the powerplant I was thinking of for my F-800. What do you have in the truck now? I think maybe a 361 or a 391 would be a good gas alternative but you may want to stay with inline 6s. Good Luck
HIO Silver
1711
11-08-2018 03:07 PM
kyle692005
1999 to 2016 Super Duty
07-11-2016 08:09 AM
jruggles
Vehicles for Sale
06-08-2015 08:30 AM
jbrianas
Modular V10 (6.8l)
04-24-2009 07:42 AM
Quick Reply: 1961 F-500 swap in the 4.9L or the 5.9L??
