transmission band adjustment?
I have a '93 F150 2wd with 302 and AOD transmission. I'm wanting to change the transmission fluid (as I often do) but this time I was wondering: are there some kind of bands or something that need to be adjusted? seems like the transmission shops talk about that sometimes. Does anyone know if my ford has this and how to do it? Thanks, Kent
Yes, Definitely change your transmission fluid at the Ford scheduled maintenance checkpoints in your owners manual. Especially AOD. My E4OD required it for the Health of My Transmission at 70k miles. When you have the xmsn pan off, take out and clean the magnet stuck on the bottom of the pan. It will have collected lots of metal particles. And clean or replace the filter.
Thank you. So i don't have to worry about adjusting any bands on these and the magnet is a great idea. Yes it is an AOD, i know it's unusual but they had a select few in 93 yet. most '92's that i've seen even have the EOD with the electronic controls but mine does not. Not sure how i wound up with it but it's original. Thanks, KS
how big is the oil pan? the oil pan on the AOD looks simular to the C-6 except it has the budlge, the only way you have a plane-jane AOD is if someone swapped it in, i have a real hard time believing this just because i used to think the same thing, then someone proved to me that ford didnt come from the factory with anything else but an E4OD with the newer vehicles.
Justin73supercamper
06-17-2016 07:21 AM
kilich
13
05-10-2016 07:06 AM
Broken40
05-01-2016 07:12 PM
tygerrrr
08-30-2009 02:50 PM
