water pump bolt torque spec - Ford Truck Enthusiasts Forums
Old 05-14-2004, 03:36 PM
Tommyquest Tommyquest is offline
Tommyquest is starting off with a positive reputation.
Question water pump bolt torque spec
Does anyone have the torque spec for the water pump bolts for a '95 psd? TIA
Old 05-14-2004, 09:06 PM
believer45 believer45 is offline
believer45 is starting off with a positive reputation.
Water pump mounting bolts 15 lb-ft
Water pump inlet bolts 15 lb-ft also
Water pump pulley bolts 12-18 lb-ft
Taken from 1995 Ford shop manual.
Dave / Believer45
Torque specs green_95 1994.5 - 1997 7.3L Power Stroke Diesel 7 06-17-2016 12:37 PM
Water Pump Lower Elbow Bolts Torque Specs djed 1999 - 2003 7.3L Power Stroke Diesel 2 03-23-2016 06:17 PM
2004 4.2 Heritage water pump torque YZ450F 1997 - 2003 F150 3 09-17-2015 05:57 AM
water pump torque peka 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 20 09-08-2015 11:50 AM
Torque Specs for 390 68_PoolvilleTX 1967 - 1972 F-100 & Larger F-Series Trucks 4 09-22-2002 11:09 AM
Tags
1997, 30l, 351m, 95, bolts, bronco, diesel, f250, ford, pump, specs, torque, vulcan, water, waterpump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
