Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-14-2004, 10:06 AM
rutherj rutherj is offline
Garage is empty, add now
rutherj is starting off with a positive reputation.
Question 534 Tune up
I have a 534 in a 1976 Bluebird Wanderlodge. I need points gap/dwell and timing specs. I looked a the previous threads but did not see them posted.
Thanks for any help.
  #2 (permalink)
Old 06-02-2004, 08:07 PM
Kenny's Avatar
Kenny Kenny is offline
Kenny is gaining momentum as a positive member of FTE.
Hi,
I'm not sure if they are the same from year to year, but my '59 shop manual shows these settings for the 534 SD.........
Breaker arm spring tension (ounces)......17-20
Contact spacing................................0.014 - 0.016
Dwell contact at idle speed................26 deg. - 28.5 deg.
Initial ignition timing (B.T.D.C.)
With reguar fuel of 85-88 octane.........4 Deg.
With reguar fuel of 88-90 octane.........6 Deg.
With reguar fuel of 90-92 octane.........8 Deg.
With reguar fuel of 92 octane or more, or premium fuel.........10 Deg.
Distributor RPM............................Advance Degrees
400............................................... ......0
600............................................... ......1-2
950............................................... ......5.75-7
1250.............................................. .....9.25 -10.25
1450.............................................. .....10.75 - 12.25
1650.............................................. ......12-13.5
*Maximum advance 13.5 Deg.
__________________
Kenny
  #3 (permalink)
Old 06-02-2004, 09:01 PM
Thanks Kenny
  #4 (permalink)
Old 06-18-2004, 10:33 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
I was just checking out other forums, usually I'm in the V10 or FE, but I have a Motor's with the '76 534 in it, and some of the specs are different than what Kenny said.
Here's the poop:
Spark Plug: BRF-31
Plug gap: .030
Point gap: .017
Dwell angle: 24-30
Firing order: 15486372
Timing: Non-Calif: 6 BTDC, Calif: 8 BTDC
Hot idle: 550 RPM
Fuel pump pressure: 5-7 lbs.
That's for 1976
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see. ®
  #5 (permalink)
Old 09-24-2004, 10:17 PM
Loan Ranger Loan Ranger is offline
Loan Ranger is starting off with a positive reputation.
If it will help you out any, I posted some tune-up specs in the "gutless 534" thread that may be of some help to you. I just checked and the thread and the post are still there.
In his post, krew said some of his specs showed up differently than what kenny posted. That is somewhat the norm on the older point-type distributors.
If you would get your distibutor tag number--located just below the cap itched in the distributor body and with a 12127 base number--I will be glad to match the tune-up specs with the distributor number for you , if you would like for me to do so.
Tags
1972, 1976, 534, 92, angle, ci, dwell, ford, fuel, gap, point, points, pump, ranger, truck, tune, wanderlodge
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
