I saw like a late 88 ranger with a dually rear end and box??
Old 05-13-2004, 08:44 PM
JSMConstruction's Avatar
JSMConstruction
JSMConstruction is offline
Talking I saw like a late 88 ranger with a dually rear end and box??
Now am i in the dark or is this daully ranger an odd ball or a custom build?? it had 6-30x9.59R15's??
it had 2.9L V-6 5spd manual not sure what gear's tho??
Old 05-13-2004, 08:48 PM
TigerDan's Avatar
TigerDan
TigerDan is offline
I saw one yesterday, just in passing so I didn't get a chance to look at it close up. It was blue, std. cab I think, wondered the same thing myself.
Old 05-13-2004, 09:33 PM
Ken00's Avatar
Ken00
Ken00 is offline
They never made them, but I do recall someone saying you could get a kit to make them.
Old 05-13-2004, 09:37 PM
79schaefer's Avatar
79schaefer
79schaefer is offline
Yes, there was a kit. I had 1 for a while back in mid 90s. I did the kit. It was a fenders, spacers and new wheels in the kit. Got alot of stares with it.
Steve S.
To many to mention.
Old 05-13-2004, 10:56 PM
JSMConstruction
so then this was a custom Built truck then??
Ok cause i have seen the Toyota,nissan,and mazda dually's.. they were mostly camper's and pluming truck's..
So i was just wondering if ford had one too... But i guess not..
Old 05-14-2004, 07:21 AM
Chris_ce's Avatar
Chris_ce
Chris_ce is offline
I seen a mid 80 ranger camper with the dual wheels.
Old 05-14-2004, 02:33 PM
racsan's Avatar
racsan
racsan is offline
i saw a 82-88 with the dually fenders, but instead of duals it had real wide rear tires. j.c. whitney has rims and fenders you can buy to build it. i thought about it once, but decided against it. the 7.5 rear end can only take so much no matter if it runs duals or singles. i like the look though.
Old 05-23-2004, 07:52 PM
roboman3234's Avatar
roboman3234
roboman3234 is offline
The bolt on Dual wheel kits like J.C. Whitney offers are dangerous if you carry heavy loads. They don't increase your truck's GVWR. A true one ton dual rear has two sets of bearings a side; centred on the tires. A single rear with bolt-on duals still has a single bearing set a side. As a matter of fact the outside tire causes sideways pressure on the bearing because the force is no longer centred on the bearing. The mini motorhome builders, that used Toyota chassis's, had this problem in 1985 when they bolted a second wheel to the rear tires. There were numerous failures that caused accidents, lawsuits and a safety recall by Toyota in the US. Toyota fixed the problem in 1986 by supplying a full floating, dual wheel, 6 bolt, 1 ton rear on their truck chassis for the motorhome builders. Don't use these bolt on dually kits and be an accident waiting to happen. As the Toyota motorhome axle failures of the mid 80's models proved; the lucky one's rolled into the ditch and not into opposing traffic when their bearings failed and the axles broke.
Old 05-23-2004, 08:00 PM
JSMConstruction
Talking
I wasn't building one Dip stick i was just saying I saw one ........
Little_ranger86
07-06-2014 02:02 PM
hush210
Engine Swaps
05-25-2008 05:36 PM
jmouellette
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
11-09-2003 10:44 AM
slapjack69
11-15-2001 04:32 PM
Tod
12-20-1999 06:26 PM
Quick Reply: I saw like a late 88 ranger with a dually rear end and box??
