Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 vanSPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2004, 04:16 PM
SBV45's Avatar
SBV45 SBV45 is offline
SBV45 is starting off with a positive reputation.
EGR disconnection
OK, anybody got specific instructions on disconnecting the EGR properly?
Will it throw a code?
EGR problems will affect fuel mileage. Will disconnecting the EGR improve mileage?
__________________
03 F250SD 4X4 6.0L PSD 5speed auto. 3.73 diff, extended cab, Raven shell. 4/2/03 build, 3/27/03 engine build.
  #2 (permalink)
Old 05-13-2004, 04:35 PM
khmorse khmorse is offline
khmorse is starting off with a positive reputation.
Good question. There was a guy on the diesel stop that said he disconnected his EGR and his MPG improved. Obviously it's there for a reason though and might not be good to have it disconnected.
__________________
Ken
'04 F350 Lariat, CC, 6.0 PSD, short box, FX4, w/camper pkg
'03 Palomino 21SDSL hybrid TT
  #3 (permalink)
Old 05-13-2004, 04:43 PM
IB Tim's Avatar
IB Tim IB Tim is offline
Site Administrator
IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation
I have read there is no change......????.wonder why
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
  #4 (permalink)
Old 05-13-2004, 05:05 PM
SBV45's Avatar
Quote:
In my discussions with the diesel tech at the service dept I use, he said the EGR valve can impact mileage. He went on to say that the EGR valve could malfunction and not throw a code.
I also believe that tampering with emissions devices is borrowing trouble.
__________________
  #5 (permalink)
Old 05-13-2004, 05:34 PM
03f350crew 03f350crew is offline
03f350crew is starting off with a positive reputation.
I drove with mine disconnected for about 1200 miles and found no effect to gas mileage and other than no difference. Initially I though it ran better but I think that was all in my head because I hooked it back up and felt no difference. In fact Mr. Lamkin drove my truck with I connected and said that it ran great. I value his opinion very much and from what I have read that the only advantage to disconnecting it is that it keeps your Intake tube clean of oil. That is the only advantage I can see so far and the intake issue I have not looked at myself, I just read it here.
  #6 (permalink)
Old 05-13-2004, 08:02 PM
SpartanDieselTech's Avatar
SpartanDieselTech SpartanDieselTech is offline
FTE Sponsor
SpartanDieselTech has a great reputation on FTE. SpartanDieselTech has a great reputation on FTE. SpartanDieselTech has a great reputation on FTE. SpartanDieselTech has a great reputation on FTE. SpartanDieselTech has a great reputation on FTE. SpartanDieselTech has a great reputation on FTE.
I unplugged mine a while back, probably 3000 miles. In terms of top end power, it will make no noticeable difference, but your turbo WILL spool marginally quicker. The EGR extracts exhaust air pre-turbo in these motors; by this token, any air the EGR uses is subtracted from the quantity that could be powering the turbo, but instead is rerouted through the intake. By pulling the plug on top of the valve, the valve is locked into the closed position and will prevent any air from being extracted. This is valuable air that, at idle-2200 rpms (estimate) will assist in getting your turbo boost up. I would be very interested to see the torque curve on a dyno with the EGR enabled vs. disabled. As for answering your original questions:
Simply pull the plug off the top of the EGR valve and wrap both male and female ends in tape (or at least thats what i did)
Yes, it will throw a code if you read it with NGS, but can simply be cleared with a tuner (diablo, superchips) or just unplugging the battery. The check engine light DOES NOT come on.
As for gas mileage, i do not carefully calculate mine, but it SEEMS to have boosted mine marginally, maybe half mile to the gallon.
PS- i also removed the throttle plate from the intake elbow (used for backpressure for the EGR, the plates are only in early model 03's and the new 04's) Both of these WILL decrease the time it takes for your turbo to spool up, by a noticeable yet not drastic amount.
  #7 (permalink)
Old 05-13-2004, 10:12 PM
Mud Doc Mud Doc is offline
Mud Doc is starting off with a positive reputation.
Off and on for several 1000s of miles, I can see no difference in performance with or without the EGR, but it sure is simple to connect/disconnect. Never has thrown a code or SES light. But, what the heck, its a mod, right?
__________________
2009 F450 Lariat CC 4x4
2005 Mobile Suites 36TK3
2007 F350 6.0 KR 4x4 CC--gone
2008 Navigator 4x4
2004 F350 6.0 4x4 CC--Gone
2002 F250 V10 4x4 CC--Gone
  #8 (permalink)
Old 05-14-2004, 01:21 AM
mobandy mobandy is offline
mobandy is starting off with a positive reputation.
The main purpose of the EGR is to direct exhaust gasses, (oxygen depleted air) into the intake manifold. This supposedly reduces combustion temperatures and oxygen content that is necessary for the formation of NOx emissions, there by reducing NOx emissions. Some of the exhaust gasses from the cylinders is diverted through the EGR before reaching the turbocharger and routed back into the intake manifold. This means that the gasses going through the EGR have to overcome the pressure in the intake manifold to enter it. It is not unreasonable to assume that at high loads, the boost from the turbocharger in the intake manifold becomes high enough to prevent exhaust gasses from the EGR from entering the intake. In other words, under heavy load the EGR may not be doing much. If that is the case you wouldn't notice much difference at full throttle with the EGR disconnected. That is probably why people don't seem to notice increased power. It may be worth mentioning that this may be the main reason that many say the 6.0L PSD needs some exhaust backpressure to run correctly. Without sufficient back pressure in the exhaust the EGR will not be able to force as much exhaust gas into the intake. I think this has the potential to have a significant impact on low and mid load performance.
Regards,
Morris
  #9 (permalink)
Old 05-14-2004, 07:28 AM
IB Tim's Avatar
Site Administrator
Quote:
Regards,
Morris
You analogy is excellent, makes perfect sense.
__________________
Administrator
  #10 (permalink)
Old 05-14-2004, 02:15 PM
PSD6litre40's Avatar
PSD6litre40 PSD6litre40 is offline
PSD6litre40 is starting off with a positive reputation.
is the EGR valve located on the Intercooler to Manifold down-spout or 90* neck? If not where is it?!?!?
__________________
- John
2008 F-250 CC Lariat Black 4x4 w/ 20's (33000 Miles so far)
Mods so far:
- 4" Cherry Bomb/Flo-Pro Duals
- Custom DOC/DPF Delete Pipe
- Spartan Phalanx w/ 250HP Tune
- S&B Intake
- Billet Fender Vent Inserts
- Toyo 35" Open Country M/T
- 2.5" Donahoe Racing Lift Kit
  #11 (permalink)
Old 05-14-2004, 03:17 PM
pdbd pdbd is offline
pdbd is starting off with a positive reputation.
how difficult was it to remove the throttle plate?
  #12 (permalink)
Old 05-14-2004, 04:20 PM
FTE Sponsor
The EGR is located on a small black cylinder (the black cylinder is the valve itself) right between the oil filter housing and intake elbow on top of the motor-just pull the plug
As for the throttle plate, it is a piece of cake. Here it goes, step by step- take the clamp off the plastic hose connecting the intercooler to the aluminum intake elbow. there are four bolts holding the elbow onto the plate below it. Remove the bolts and pull the intake elbow off. this will reveal the plate, mounted to a crossbar going across the intake assembly where the motor for the throttle plate and its position sensor are located. There are two small screws holding the throttle plate on, #10 torx if im not mistaken (youll have to check, i cant remember) simply rotate the plate to the closed position and remove the two screws. It would be in your best interest to have a magnet handy to pick them up, you DO NOT want to drop them down the intake. pull the screws out and rotate the throttle plate back to the open position, remove it, and bolt the intake back on. Clamp the hose back on, and your done. If a 17 year old can do it, you can...its not hard, and its well worth the 10 minutes, just IMO...
  #13 (permalink)
Old 05-14-2004, 05:08 PM
Good to see I will be able to do it, me being 18 LOL
__________________
- John
Mods so far:
- S&B Intake
  #14 (permalink)
Old 05-14-2004, 06:17 PM
johnsdiesel's Avatar
johnsdiesel johnsdiesel is offline
johnsdiesel is starting off with a positive reputation.
Quote:
What I would have given at 17 or 18 to drive a BRAND NEW diesel pickup, let alone any new car or truck.
__________________
1997 F250 HD PSD SuperCab 4X4 ZF5 4.10
173K miles
CMP Info1
CMP Info2
  #15 (permalink)
Old 05-15-2004, 06:31 PM
FTE Sponsor
one thing i forgot to mention- the difference will only really be felt at partial throttle. the modification DOES make a small difference at WOT, but only in first gear, and not to the extent it does below 3/4. I have not thought of a logical explanation for this, it is probably due to the things mobandy listed in his excellent technical explanation.
Tags
60 , delete , egr , gas , improve , mileage
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
