1988 E150 Conversion Fuel Pressure Issues - Page 5 - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
  #61
Old 02-15-2014, 09:50 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
First you need to take a voltage reading at the battery with the engine not running.
Then take a voltage reading at the battery with the engine running.
If no change or less voltage the alternator is not charging the battery.
If you get higher voltage (13.5-14.5) the alternator is charging the battery.
If it is not charging try running a jumper wire from the POS + post of the battery to the light green wire with a red stripe at the back of the alternator (you may have to stick a pin in the wire to make connection as the wire goes into a plug).
Now take another voltage reading at the battery with the engine running.
Does it charge now?
If so and it did not before you may have a bad Instrument Cluster.
If it did not charge you need to check the 14 Ga green fuse link going to the battery side of the starter relay from the alternator. The wire from the fuse link to the alternator may be a black wire with a orange or red stripe.
To check a fuse link just try to stretch it and if it stretches it is bad.
Fuel pressure loss after the truck warms up Shawn Paris 1987 - 1996 F150 & Larger F-Series Trucks 12 08-02-2016 10:56 PM
No fuel pressure?!? Atphelan 1987 - 1996 F150 & Larger F-Series Trucks 7 12-20-2015 06:14 PM
Where is check valve? Hotairjunkie Fuel Injection, Carburetion & Fuel System 8 06-30-2014 04:42 PM
Fuel delivery question Boodrow379 1987 - 1996 F150 & Larger F-Series Trucks 2 04-24-2014 09:24 AM
Low fuel pressure at fuel rail kevin206 1987 - 1996 F150 & Larger F-Series Trucks 3 04-20-2014 01:38 AM
Tags
1988, 88, 89, e150, ford, fuel, gas, mechanical, overflowing, presure, regulator, tank, truck, valve, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
