1988 E150 Conversion Fuel Pressure Issues - Page 4 - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
  #46
Old 04-05-2011, 05:46 PM
Tom108 Tom108 is offline
Tom108 is starting off with a positive reputation.
Run the vehicle at night in the dark and see if the wires have any blue sparks anywhere especially where they touch ground or each other. Also inspect the wires and look for burnt or charred areas where they come into contact with anything. Bad or old wires can cause voltage leaks which can overload all the ignition components and cause overheating and failure of any of the components, the distributor pickup, the distributor cap, the coil, or the ignition module. Also inspect the inside of the distributor cap and rotor for burnt or corroded terminals and clean or replace the cap and rotor. If you don't find any obvious damage or spark leakage here's what you can try, spray all the wires and distributor with WD-40 and let them sit for about ten minutes, this will draw the moisture from the wires and they should work for about a month if they are bad. This is just a temporary fix and the wires will have to be replaced. Just some things you can try.
  #47
Old 05-03-2011, 05:48 PM
Lady.Connoisseur Lady.Connoisseur is offline
Lady.Connoisseur is starting off with a positive reputation.
wow, lots of great info, hope someone can help me with my issue [see my post]...where is/are the fuel relay fuses located? being a woman, a mechanic is trying to take me to the cleaners, so would love some help here. lady dot connoisseur at hot mail dot com
  #48
Old 06-11-2012, 10:00 AM
Green Griffin 420's Avatar
Green Griffin 420 Green Griffin 420 is offline
Green Griffin 420 is starting off with a positive reputation.
Quote:
Originally Posted by Mustang 5.0 View Post
Selector valve assy, p/n F1UZ-9B263-B $ 77.99 plus shipping from www.fordpartsnetwork.com for my 89 E-150
Will this be the same part number for a 94 F150? Mines a 5.0 with MAS air. Mine isn't dieing like others in the thread, but it does fill one tank to another. Also is there a specific part number for the sock filters for the fuel pumps?
  #49
Old 06-11-2012, 12:27 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Green Griffin 420,
You do not have a selector valve on your truck.
You do have a frame mounted filer for the injectors.
There are sock filters in the bottom of each tank for the fuel pumps.
The tank that is filling has a bad check valve inside the tank. That check valve is also inside the Fuel Delivery Module (FDM).
  #50
Old 06-11-2012, 04:25 PM
Quote:
Originally Posted by subford View Post
Green Griffin 420,
Thanks. I also want to add that mine fills both ways. if the front tank is empty and I fill the rear, the rear will slowly fill the front, and vice verse.
  #51
Old 06-11-2012, 05:24 PM
subford's Avatar
Then you have two FDM with bad valves in them.
  #52
Old 06-12-2012, 12:47 PM
mustangman mustangman is offline
mustangman is starting off with a positive reputation.
i put all new rear tank,both pumps,sending unit,lines,and threw front tank in the garbage where it belongs,no more transfer valve sht, put direct 12v switch to pumps,,,ah so simple,,,do you really need more than 22 gallons? , oh yeah also replaced fuel pressure regulator with a spare one i had off a a 2.3 efi fit right in the fuel rail,the 2.3 uses the same pressure for its efi so i guess its ok, 5.0 1987 econoline runs fine with it and all systems go
  #53
Old 06-13-2012, 08:47 AM
I thought they only had 1. Is there one for each tank?
  #54
Old 06-13-2012, 08:52 AM
subford's Avatar
Quote:
Yes one in each tank for a total of two FDM.
Look at the diagram I posted above.
  #55
Old 06-13-2012, 11:06 AM
fordparts.com doesn't show an FDM for my truck. they show a fuel sender and a fuel pump and strainer set. Neither look like the pic above. So i'm a little confused.
  #56
Old 06-13-2012, 11:32 AM
subford's Avatar
I can not make heads or tails out of that site either.
But part stores seem to rename the item to what they think somebody will call it when they ask for it.
They do not seem to care what the Ford shop manuals call it.
Here is one from advance:
Buy Airtex Electric Fuel Pump E2059MN at Advance Auto Parts
  #57
Old 06-13-2012, 12:21 PM
Thanks subford
  #58
Old 02-14-2014, 08:17 PM
07terry 07terry is offline
07terry is starting off with a positive reputation.
alternator gauge
i'm new here could you guys please help me find how to trouble shoot the alt on a 88 f-150 351 4x4 , im in the wounded warrior and it takes me a while to do the checks this is my 15 year old daughters trk we just got, has been on my wifes uncle's farm and has 100,021 miles and has been taken care of just needs some tlc and cleaning thx in advance
  #59
Old 02-15-2014, 08:54 AM
subford's Avatar
Quote:
You should start your own thread as you will get better responses.
What do you have to work with (volt meter, jumper wires with clips, ...)?
  #60
Old 02-15-2014, 09:22 AM
all and my father has a garage with lift also my brother and oldest son will help
Fuel pressure loss after the truck warms up Shawn Paris 1987 - 1996 F150 & Larger F-Series Trucks 12 08-02-2016 11:56 PM
No fuel pressure?!? Atphelan 1987 - 1996 F150 & Larger F-Series Trucks 7 12-20-2015 07:14 PM
Where is check valve? Hotairjunkie Fuel Injection, Carburetion & Fuel System 8 06-30-2014 05:42 PM
Fuel delivery question Boodrow379 1987 - 1996 F150 & Larger F-Series Trucks 2 04-24-2014 10:24 AM
Low fuel pressure at fuel rail kevin206 1987 - 1996 F150 & Larger F-Series Trucks 3 04-20-2014 02:38 AM
Tags
1988, 88, 89, e150, ford, fuel, gas, mechanical, overflowing, presure, regulator, tank, truck, valve, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
