Lamp Outage Module - Ford Truck Enthusiasts Forums
Lamp Outage Module
Old 05-12-2004, 08:46 PM
Gemini19th81 Gemini19th81 is offline
Gemini19th81 is starting off with a positive reputation.
Lamp Outage Module
Hi, I have a 96 explorer and the lights won't come one but the tail lamps works. basically it all works but the lamps themselves won't come on unless I pull the high beam switch towards me (so i have to drive holding the level towards me with highbeams). Someone suggested that something called the lamp outage module controls the current going to the lights and if this is faulty then the lamps won't come on and the computer won't pick up any headlamp problems. Does anyone know where this module is located so I can take a look at it and see if there are any loose connections, etc.
Thanks
Old 05-12-2004, 09:30 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
Well first off, unless you have a message center in the console, you dont have a LOM. If you have a message center then yes it could be related to the LOM. But usually it does quirky things like only one headlamp works. I would trace the circuit from the fusebox to the headlamp switch to the multifunction switch and out from there first.
Old 10-22-2005, 09:57 PM
Dougeee Dougeee is offline
Dougeee is starting off with a positive reputation.
Lamp Outage Module
Gemini19th81, I know this post is incredibly old... but to answer your question, Yes, your problem is the Lamp Outage Module. I too have a 1996 Explorer (Limited) and had the exact problem. And in fact, if you do a little research online, you'll notice that HUNDREDS of other explorer owners have been having the same problem too.
The L.O.M. is located directly beneath the message center. You can just pop off the message center screen by squeezing the sides. The cup holder comes off the same way. The Lamp Out Module should be on the passenger side of the console, about where the passengers knee would be. It's got a bunch of wires plugged into one side, it's about the size of a pack of cigarettes, held on by 2 screws. Once you have it removed, you can open it up. there's a few clips keeping it closed, it can be kinda tricky. When you get it open, you should be able to clearly see a burned area around a few of the resistors.
If you want to save yourself $300, you can just use a soldering gun to touch up the burnt contacts, or take it to an electronics shop. I'm sure they wouldn't even charge you for something so simple. Ford should have recalled this years ago. I hope this helps.
Old 10-23-2005, 06:56 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome Dougeee, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Another brake light switch concern brokersteve 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-16-2017 11:39 AM
Cruise control not working Cummins7mm 1987 - 1996 F150 & Larger F-Series Trucks 0 04-22-2016 11:07 AM
2014 f-150 no front turn signals. Puddy 2009 - 2014 F150 6 12-08-2015 06:18 PM
A word or two about lighting/electrical circuits greystreak92 1978 - 1996 Big Bronco 17 03-27-2012 07:53 PM
95 Explorer Lamp Out Warning Module cstigas Explorer, Sport Trac, Mountaineer & Aviator 14 08-20-2004 08:13 AM
Tags
1996, 1997, 2000, 97, explorer, f150, ford, lamp, location, lom, module, outage, proper, resistors, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
