Ford F150 No oil pressure
Got a Ford F150 1997, installed a new long block motor 4.2ltr, new oil pump, new water pump, etc. No oil pressure. disconnected oil sending unit and inserted a oil pressure gauge into to oil pressure sending unit hole and no oil pressure. The engine was properly primed and the new oil pump was switched out to be sure that was not the problem. With the oil sending unit hole free of the oil sending unit and the gauge, when the motor is cranked (not started) oil will shoot up out of this hole, but yet when a gauge is hooked up there is no oil pressure. Can anyone tell me what's up?
The valve covers were loosened and the engine was cranked and there is no oil being pumped up into the valve, lifter area. (Sorry I'm a woman and am posting this for my husband). It seems like the engine is unable to hold oil pressure. Because it is pushing oil up out of the oil sending unit hole, we are assuming that the oil pump is working and that the pick up tube and screen are in correct working order. This is a new motor purchased from ProPerformance and our mechanic us ASE certified. We are pretty much dumbfounded by this. Any suggestions? Ford says it sounds like we were sold a bad motor with too much space between the bearings.
Found out the problem.....the pick up tube and screen are too close to the oil pan. They are hitting the bottom of the oil pan creating a vacuum and shutting off the oil from the tube. Had to take the motor back out of the truck since you can't get the oil pan off while it is in the truck (not enough clearance). Which was not fun, but at least we found the problem. thanks to all though.
Rocketattack
04-25-2016 09:00 PM
FordXLT1990
11-27-2015 08:14 AM
ink
08-03-2015 02:47 PM
gerald broussard
03-06-2014 08:02 PM
peterbilt379exhd
07-17-2005 08:33 PM
