Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-12-2004, 06:44 PM
tinsmith tinsmith is offline
Garage is empty, add now
tinsmith is starting off with a positive reputation.
BioDiesel what do you think?
I'm looking into using Biodiesel in my 6.9, with the cost of fuel today it might be the only way to go.
What do you think??
__________________
George
83' F250 2WD 6.9 Banks Turbo, Solid C6, 102000 and strong......
USCG Retired
This truck is for sale
  #2 (permalink)
Old 05-12-2004, 06:48 PM
johnsdiesel's Avatar
johnsdiesel johnsdiesel is offline
johnsdiesel is starting off with a positive reputation.
Make sure you don't have any rubber parts in your engine. Biodiesel causes them to deteriorate. Other than that, I have heard that it produces at least the same amount of power and lubricates the engine much better. I'm considering making some myself.
__________________
1997 F250 HD PSD SuperCab 4X4 ZF5 4.10
173K miles
CMP Info1
CMP Info2
  #3 (permalink)
Old 05-13-2004, 09:28 PM
browning1919 browning1919 is offline
browning1919 is starting off with a positive reputation.
I have not tried it in my truck, but my friend tried it in his VW TDI. He used 100% bio and we noticed a decrease in acceleration and power. It may have been a poor mix that he got. He has been thinking of trying a blend to see if that changes his luck.
  #4 (permalink)
Old 05-13-2004, 10:12 PM
redneckmechnic redneckmechnic is offline
redneckmechnic is starting off with a positive reputation.
any one no were to get a simple method for making it. id love to make some to have. in the summer i get free fuel from were i work but come fall when i head back to school i dont. if i could stock pile some to have that would be great.
__________________
85 ford F 250 6.9l 5 speed 4x4 7.5ft snow plow flatbed with dual 4inch stacks 270,000 miles and counting
  #5 (permalink)
Old 05-13-2004, 11:19 PM
http://www.afdc.doe.gov/altfuel/biodiesel.html
__________________
George
USCG Retired
  #6 (permalink)
Old 05-14-2004, 12:23 AM
http://www.biodieselsolutions.com/
This looks like the best way to make your own BioDiesel, and with the price of fuel today it makes one think.
__________________
George
USCG Retired
  #7 (permalink)
Old 05-14-2004, 08:40 AM
thanks for the good links. makes me wonder if i could build somthing like the fuel mizer thinger for cheaper then 3 grand. maybe with alittle more capcity. if i could run my whole farm off of that stuff i could save alot of money each year. problem is off road diesel is 1.24 so the savings isnt as great.
__________________
  #8 (permalink)
Old 05-18-2004, 09:36 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
1984 Ford Bronco
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
i would say go biodiesel. its not hard to make, and you can eisily get oil from your local fast food joint. you would also need lye and some ethanol/methanol. mix it w/diesel some depending how much you make, if you want to run it in the engine you have w/no modifications i would say mix it around 50/50 cause pure biodiesel will eat rubber and lose some power, but i dont think its a huge loss, if it cost less you can save up to modify that french fry cooker!
__________________
1973 f250 highboy 4x4
1984 full size bronco, -DIS, wide band megasquirted 300 and np435 w/ dual range aux tranny on the way! - finally updated! 12/29/2011
1988 f150 extended cab 4x4, mostly stock.
1984 mercury capri, 5.0 conversion, my little monster...
1961 ford falcon, all stock, in family since '68
  #9 (permalink)
Old 05-18-2004, 10:35 AM
I joined a Co-op in Portland that is building a Processer to make Biodiesel, most of the people in it have been running 100% Biodiesel for the last 2 years. The cost is less then half of Diesel, and I have asked them about the rubber issue. Not one of them has had any problem at all.
__________________
George
USCG Retired
  #10 (permalink)
Old 05-19-2004, 01:16 AM
FORD DIESEL FORD DIESEL is offline
FORD DIESEL is starting off with a positive reputation.
Quote:
I would like to learn more about co-op //all of your co-op have what type equiptment in their vehicles & were do they buy the equipt at.
  #11 (permalink)
Old 05-19-2004, 10:19 AM
Hi,
Here is the link for the group http://www.gobiodiesel.com/tiki-index.php
As far as buying anything extra for the vehicle, the only thing will be is Fuel Filters. The Diesel seems to clean out the tanks and you will have to change a few filters. But other then that, just put it in and take off. Also you can go here and make your own,
__________________
George
USCG Retired
  #12 (permalink)
Old 05-19-2004, 11:22 PM
HardScrabble HardScrabble is offline
HardScrabble is starting off with a positive reputation.
Here is your recipe for a small homemade batch of Biodiesel. I didn't say I recommended it, but here it is.
http://www.dangerouslaboratories.org/biodiesel.html
  #13 (permalink)
Old 05-19-2004, 11:40 PM
Thanks, but I am making it a little bigger then that. Try 50 gal. at a time.
__________________
George
USCG Retired
  #14 (permalink)
Old 05-28-2004, 03:54 PM
Chopperbob Chopperbob is offline
Chopperbob is starting off with a positive reputation.
Greasecar
WWW.Greasecar.com
  #15 (permalink)
Old 05-29-2004, 12:51 PM
Teedo47 Teedo47 is offline
Teedo47 is starting off with a positive reputation.
Biodiesel processors
I bought an '86 6.9 for the purpose of using biodiesel and vegetable oil. Don't but the online processor kit, it has plastic tanks and biodiesel loves to corrode plastic. Those tanks can catastrophically fail, spewing hot oil and methanol. A better option s using an old electric water heater tank. You can buy dented floor models from a hardware store pretty inexpensively, but old used ones work fine, too. The heat helps process the fuel, and water heater tanks are insulated for efficiency and then can withstand lots of pressure. Water heaters also come with all the holes you need, and can be modularly swapped for bigger tanks and methanol recovery still can be attached to them. Plans for this type of system and the designer's contact information can be found at:
http://www.veggieavenger.com/avenger...opic.php?t=332
This is the type of system i built, but schoolwork and a lack of a ventilated garage has prevented me from making any yet
But I do know a couple guys who have used this setup to make many batches of good fuel (good enough for his newer 7.3 DI turbo)
This summer I will be re-plumbing my fuel lines to used SVO (straight vegetable oil=unprocessed fryer grease) in one of my tanks. If anyone is interested i can post/email them a play-by-play when i do it in late july/early august.
Happy biofueling!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
