new to biodiesel-- hauling horses
Hi, I'm new to biodiesel but would like to start using B-20, which is readily available in my area, in my Ford F250 powerstroke diesel. It's a high-miles truck, but it good shape and relatively new (2000).
I have gone to the national biodiesel website and researched it, so I got a lot of questions answered there, but I had a couple questions they couldn't answer:
Is there anything I should know about using biodiesel in an f250 in particular? It's new, so I think all the rubber is non-synthetic.
Has anyone had experienced hauling with biodiesel? I'm guessing from the fleets I have seen around town using biodiesel it shouldn't be a problem.
I need to have the transmission serviced, and I am wondering if I should try to seek out a mechanic who work specifically on biodiesel, or if it doesn't matter, since I will be using B20.
thanks!
Zella
thanks!
Zella
Zella,
With B20 you should have no issues.
You might have to change the fuel filter after the 3rd or 4th tank of B20.
I would carry a spare fuel filter with you just in case you plug up the one on the tank.
I started to use B99 on my 95 with 140K on it with no issues. I pulled the fuel filter after the 2nd tank and there was nothing in it.
