C6 Rebuild - Ford Truck Enthusiasts Forums
C6 Rebuild
Old 05-12-2004, 12:30 PM
ramboss429's Avatar
ramboss429 ramboss429 is offline
ramboss429 is gaining momentum as a positive member of FTE.
C6 Rebuild
How much does it usually cost to have a C6 rebuilt that can handlel some decent power from a 390?
Right now the C6 has a 360 bolted to it, what will I need to buy to bolt my 390 to this tranny? If anything?
Old 05-12-2004, 01:48 PM
Steve_Uzi Steve_Uzi is offline
Steve_Uzi is starting off with a positive reputation.
I have a C-6 behind my 360 and when it was rebuilt the guy used a heavy duty Trans-Go kit and that tranny has taken a beating from me.. granted it is stock power.. but I have hauled car trailers (yes I know its only a 1/2ton). I have burnt many tires off the rimes (yes I know immature) and it was rebuilt in 1992! He charged me $600
The same guy built the C-6 4wd for my 1984 Bronco which has a 460 pushing approx 420 hp and 500 ft-lb's of TQ. I don't roast tires with this truck (though I could, them 32" BFG's cost too much) but I do tow a 2 or 4 place snowmobile trailer during the winter. He used the same heavy duty Trans-go kit, I have a TCI Truckmaster torque converter in their as well as the AOD 1st and 2nd gear planetaries. That rebuild was done in 2002 and cost me $900, but that included the cost of the AOD planetaries.
So I am saying I enjoy both of my C-6's with the Trans-go kits
The 360 has the same bolt pattern as the 390. All FE Engines(352,360,361,390,391,406,410,428)
Old 05-12-2004, 04:45 PM
TNTsF-250 TNTsF-250 is offline
TNTsF-250 is starting off with a positive reputation.
ramboss429, i just put a reman C-6 in my 2x4 75 F-250 CS, and what steveUzi said i also had the HP trans-go kit installed, I'm running a 390 engine, HP Comp cam 268/502 lift 750 holley,runs real strong, she'll bark off 2nd. gear , go for it ! !
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
